Bikerz Posted May 26, 2006 Report Share Posted May 26, 2006 I dont know if this is where I should ask this, but im guessing its best placeJust got T1's on my lupo, what pressure should i run them at for daily driving?CheersSheldon Quote Link to comment Share on other sites More sharing options...
Max69vk Posted May 26, 2006 Report Share Posted May 26, 2006 I cant for the life of me remember what it is but Im running the same tyres on my Arosa, the only way I can double check is that there is a factory fitted sticker on the inside of the petrol flap that should tell you. Quote Link to comment Share on other sites More sharing options...
nfbr Posted May 26, 2006 Report Share Posted May 26, 2006 29 and 31psi, not sure which for front or rear though lol... Quote Link to comment Share on other sites More sharing options...
LINCOLNSHIRESLUPOGTI Posted May 26, 2006 Report Share Posted May 26, 2006 On my 205/40R17 Toyo Proxes I run 32-34psi front and 32-30 psi rear.Suppose it depends on tyre size, weight in the car, the type of driving you do and your suspesion geometry but 30-34psi front and 28-32 rear would probably be fine. They will adjust on hot/cold days and long high speed runs anyway so a couple of psi difference is trivial unless you are on the track. Quote Link to comment Share on other sites More sharing options...
cardaft Posted May 26, 2006 Report Share Posted May 26, 2006 Look in your fuel door, i think its 30psi in the front and 28 in the rear for the lupo sport and mine which has the same size wheels. Quote Link to comment Share on other sites More sharing options...
Bikerz Posted May 28, 2006 Author Report Share Posted May 28, 2006 Cheers all. Well the fuel cap pressure will be for trh stock tyres, wondering what Toyo recomend on there T1's.Cheers Lincolonshire GTI Quote Link to comment Share on other sites More sharing options...
Max69vk Posted May 28, 2006 Report Share Posted May 28, 2006 (edited) Im running the Toyos & have always used the pressures for the 195x45x15 that are on the fuel flap. Even though Toyo are the tyre manufacturers I'd always use Seats' reccomendations as different vehicles will always require different pressures, the make of tyre wont alter what pressure is required in them. Edited May 28, 2006 by Max69vk Quote Link to comment Share on other sites More sharing options...
Bikerz Posted May 28, 2006 Author Report Share Posted May 28, 2006 I know they are car specific too, so thourgght id just see what toyo recomened. Do tyre manufactures neer give a recomended presure then? and you just go by the car one? Quote Link to comment Share on other sites More sharing options...
Max69vk Posted May 28, 2006 Report Share Posted May 28, 2006 Most, if not all tyre manufacturers will only reccomended a rough minimum & maximum pressure so you dont pop them! Quote Link to comment Share on other sites More sharing options...
Petrified Posted May 28, 2006 Report Share Posted May 28, 2006 my toyos (195/45/15) are at 28psi on the front and 26psi on the rear, but the car is a bit lighter than standard.what size wheels are you running? Quote Link to comment Share on other sites More sharing options...
Bikerz Posted May 28, 2006 Author Report Share Posted May 28, 2006 Im using stock 14" sport wheels so 185/55/14 Quote Link to comment Share on other sites More sharing options...
