greg_m Posted October 4, 2005 Report Share Posted October 4, 2005 ive been on here and keep seeing posts about a 3L what is it?as im verry confused style="vertical-align:middle" emoid=":blink:" border="0" alt="blink.gif" /> Quote Link to comment Share on other sites More sharing options...
payna Posted October 4, 2005 Report Share Posted October 4, 2005 as far as i know its a 1.2 litre turbo deisel style="vertical-align:middle" emoid=":confused:" border="0" alt="confused.gif" /> dont think it was available over here though. iam sure someone will be able to correct me though style="vertical-align:middle" emoid=":blush:" border="0" alt="blush.gif" /> Quote Link to comment Share on other sites More sharing options...
Petes 16V Sport Posted October 4, 2005 Report Share Posted October 4, 2005 its a 1.2 TDI, streamlined with different styling/lighter components so it only uses 3Litres of fuel per 100km... hence 3L style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
Petrified Posted October 4, 2005 Report Share Posted October 4, 2005 which lupo has the fsi engine then? Quote Link to comment Share on other sites More sharing options...
db Posted October 4, 2005 Report Share Posted October 4, 2005 None in this country use FSi engines, not sure about the continent though, the 3L also came with DSG. Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted October 4, 2005 Report Share Posted October 4, 2005 (edited) border="0" class="linked-image" />Please excuse my dad's backside in this picture, he'll be thrilled i posted this! border="0" class="linked-image" />These were taken in portugal whilst on holiday! visited a dealer to see what the fox was like, and this was parked-up next to it! Was around the £12000 mark i think! Edited October 4, 2005 by lupogtiboy Quote Link to comment Share on other sites More sharing options...
Cliveski Posted October 4, 2005 Report Share Posted October 4, 2005 DSG would be nice MMMMmmmmmmm style="vertical-align:middle" emoid=":wub:" border="0" alt="wub.gif" /> Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted October 4, 2005 Report Share Posted October 4, 2005 This is copied directly from a Vw Self Study Book that i got from work! The 085 electronic manual gearbox was developed specially for the Lupo 3L and is operated by meansof an electronic gate selector lever. The development goal was to reduce fuel consumption.This gearbox is based on conventional manual gearbox 085 which was revised to incorporate severalweight-saving measures.To save weight:- the shafts were drilled hollow- the crown wheel was drilled- the 5th gear is spoked- the cheeks of the gear wheels wererecessed to make them lighter- oil capacity was reduced by 0.2 litres whilemaintainingthe same oil level by modifying the housingWhy a manual gearbox?A manual gearbox has the following advantagesover an automatic gearbox:- it is lighter, and- it is more efficientA manual gearbox with the characteristics ofan automatic gearboxThere is no clutch pedal. The manual gearbox isoperated automatically via a hydraulic selectorlever.A control unit decides what gear is to beengaged by means of the selector. As a result,the engine operates in the optimal torque rangewith regard to fuel economy.Despite having the characteristics of anautomatic gearbox, the manual gearbox stillprovides a choice of automatic or manualgear-changing.The manual gear-changing mechanism is thesame as in the Tiptronic.The ´Stop´ position is not equivalent to the ´Park´ positionin an automatic gearbox. It is also necessary to apply thehandbrake. If the handbrake is not applied, a warning lampon the dash panel will flash for up to 5 minutes.The driver can move the electronic gate selector lever into twoselector gates.The gear change systemUpshiftsMiddle positionDownshiftsTo put the vehicle in reverse, press the Lockbutton at the head of the gate selector leverand the brake.In the neutral position, it is possible to start theengine when the driver's door is closed and thebrake is pressed at the same time.In this position, gears are engagedautomatically.In Economy mode, the stop/start function isdeactivated and the vehicle runs veryeconomically.The engine is shut down automatically when thevehicle is stationary and first gear is selected.The can be started as soon as the driver's door isclosed and the brake pedal is pressed.Automatic gearshifts Manual gearshiftsEven in Economy mode, the drivercan still utilise the engine's full powerby means of a kickdown function.In Tiptronic mode, each gear is engagedindividually.System designThe electronic manual gearbox comprises three main elements:● the electrics● the hydraulics, and● the mechanicalsElectronic manual gearbox 085The electricscomprise sensors, actuators and the gearbox control unit. The control unit can recognise the actual stateof the system, e.g. what gear is currently engaged, from the signals which the sensors generate.The input signals are processed in the gearbox control unit. The output signals for activating theactuators are then calculated, e.g. for a gearshift operation.The components the electrical system are:- The electronic gate selector leverA single potentiometer and three micro-switches on the gate selector leverdetermine the position of the selector lever and transmit this information to thegearbox control unit.- The electronic accelerator pedaltransmits the current position of the accelerator pedal to the engine control unit.The engine control unit then transmits a corresponding signal along the CANdatabus to the gearbox control unit.- Potentiometer on selector and clutch actuatorOne potentiometer recognises the selector gate position.The second potentiometer recognises the gear row, e.g. 3rd or 4th gear.The potentiometer on the clutch actuator recognises the current clutch position.- The gearbox control unitcalculates the optimal gear position on the basis ofthis information and activates the gearshift operation.- An electro-hydraulic valve for the clutch actuatoris activated when the clutch is activated via the hydraulics.- Four electro-hydraulic valves on the selector leveradmit the system pressure to the hydraulic piston in the gearselector depending on requirements and activate a gear operation. Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted October 4, 2005 Report Share Posted October 4, 2005 The hydraulicsThe system utilises the hydraulics to execute thenecessary movements, e.g. clutch engagement/disengagement or gearshift operationsThe components the hydraulics are:- A hydraulic pump and pressureaccumulatorgenerates the system pressure which isrequired in order to be able to performgearshifts and operate the clutch.The pressure accumulator keeps sufficient oiland pressure in reserve to allow a quickresponse.- A clutch actuatorengages and disengages the clutch duringgearshift operations.- A selector levermoves the selector shaft via hydraulic pistons.The mechanicalsare the same as in manual gearbox 085The individual gears are engaged viathe selector shaft:- The selector gate is selectedthrough rotation of the selector shaft- A gear is selected through backwards andforwards movements of the selector shaft. Quote Link to comment Share on other sites More sharing options...
