1.4 8v 44kW - Interference engine or not?
Mefjoe
Hello!
I’m looking for people with experience working on these engines (AUD engine specifically) who know if the valve heads are within striking distance of the pistons may the timing belt snap. I can not find any specific info on whether these engines are interference engines or not.
Long story short for a little context, waterpump bearing sounds worrying and timing belt with waterpump will be replaced next wednesday. I have been out of luck trying to find alternatives for travel to work.
I fear that the waterpump may seize and knock the belt out of it’s seats. May the pump fail and the belt survive i would be able to pull over to prevent overheating though. Work is only about 7 miles away and no highways or such.
Will i be risking a set of ruined valves and engine or will be an overheating issue be my main concern?
Greetings,
It's all risk isn't it.
Take your chances or don't.
Your call, I'm not vindicating anything.
Edited by Rich
