1.4 8v 44kw manual gearbox alternatives
Lupinator
Hi,
Please help, couldn't find any approved info about Lupo 1.4 8v 44kw 2003 manual gearbox alternatives, i do not believe there is no other VW models having same gearbox, maybe somebody from here can help me with this question?
Thank you!
Edited by Lupinator
The main difference is the gear ratios (and minor linkage changes). If you put a box in from a 1.0, the car will simply rev higher.
What happened?
2 hours ago, mk2 said:
Good info 👍🏻
@ObjectiveAwayDo you have the details for other Lupo gearboxes- and the cross references - which other cars use the same types?
I have all the cross references of all gearbox codes. Details for all 085 gearboxes is also available on this page, which I often use, but those cross references contains only Polos and are not good overall.
Edited by ObjectiveAway
