chrisbwy Posted August 2, 2023 Report Share Posted August 2, 2023 Hi All, I'm just about to begin restoration of my GTI rear beam. The rear stub axle mounting plates are quite crusty. Only one side, part number 6E0501466A, is available from VW Classic Parts. So two questions please... 1. I assume these two parts, 6E0501466A and 6E0501465A must be handed somehow. In what way? Could I convert/modify two 6E0501466A to fit? 2. Does anybody remanufacture this part? I have had a company called Epytec suggested but they only appear to offer a camber adjustment plate. Any help much appreciated, Thanks Chris Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted August 4, 2023 Report Share Posted August 4, 2023 6E0 501 466 A is for the O/S only 6E0 501 465 A is for the N/S only These are Lupo GTI-only parts as far as ETKA lists. The O/S one should be available through VW Heritage parts but can take 6-8 weeks to arrive. I can't find any aftermarket ones listed anywhere, so you'll need to find a good second-hand one if you want to replace the N/S one. Though tbh, you could probably have one made out of a suitable thickness metal at somewhere that fabricates parts. Quote Link to comment Share on other sites More sharing options...
Rich Posted August 5, 2023 Report Share Posted August 5, 2023 https://epytec.de/en/brake-system/adapters/2501/vw-golf-r32-corrado-1-2-3-s3-rear-brake-caliper-adapter-g60-vr6-256x22 Quote Link to comment Share on other sites More sharing options...
chrisbwy Posted August 9, 2023 Author Report Share Posted August 9, 2023 Many thanks to you both for your info, much appreciated, regards Chris Quote Link to comment Share on other sites More sharing options...
