raining Posted January 10, 2022 Report Share Posted January 10, 2022 (edited) I've searched for an answer to this problem with a rabid hole of possibles. Rear wipers and washer ok.. Front wipers no intermittent or normal speed. Front wipers Full speed is slow speed. Front washer works. Tried with wipers lifted off screen still no movement. Fuses checked none blown but fuse 7 wasn't a good connection so changed but no difference. Sprayed contact cleaner into the base of the stalk and all worked, tried the whole sequence several times then it was back to the above problems. It might need more cleaner but the little pipe flicked of and disappeared into the ether. I've read about linkages and motor which don't seem to fit with the above? Also no auto park. Any ideas please. Edited January 10, 2022 by raining last line added Quote Link to comment Share on other sites More sharing options...
mk2 Posted January 10, 2022 Report Share Posted January 10, 2022 Most likely the control switches, but could also be a dodgy power feed via ignition sw or a relay. There's a how-to in here somewhere with pics 👍🏻 Quote Link to comment Share on other sites More sharing options...
raining Posted January 10, 2022 Author Report Share Posted January 10, 2022 (edited) Thanks for the reply, a few years back and I would have had a go but the fingers don't work very well these days and too much can go wrong and it's a friends car. Once I find the cleaner pipe I'll give it some more cleaner otherwise it.. Looks like a garage job. Edited January 10, 2022 by raining 2nd para Quote Link to comment Share on other sites More sharing options...
Rich Posted January 11, 2022 Report Share Posted January 11, 2022 Location? Quote Link to comment Share on other sites More sharing options...
raining Posted January 13, 2022 Author Report Share Posted January 13, 2022 Near Bulwell nottingham Quote Link to comment Share on other sites More sharing options...
Rich Posted January 13, 2022 Report Share Posted January 13, 2022 Too far. I'd have done it on your driveway. Quote Link to comment Share on other sites More sharing options...
raining Posted January 13, 2022 Author Report Share Posted January 13, 2022 Would Derby be too far ? Quote Link to comment Share on other sites More sharing options...
