Unmutual 2 Posted February 16 Report Share Posted February 16 Hi folks! I've recently purchased a '99 1.4 lupo, and I'm loving it, although there's a few issues with it, and I could do with some advice. The electric windows don't work at all, neither does the central locking. A friend suggested this could be a module fault, but couldn't shed anymore light on it! The drivers side window appears to be completely dead, but the passenger side does appear to click (relay?) and the lights dim when I try the switch, so assume there's something stuck rather than a total failure? Any ideas? Quote Link to post Share on other sites
mk2 361 Posted February 16 Report Share Posted February 16 See the how-to thread... may be worth checking fuses first welcome to CL! 1 Quote Link to post Share on other sites
Unmutual 2 Posted February 18 Author Report Share Posted February 18 So I popped the door cards off today, and discovered why the windows weren't working... Someone has wedged a length of 2x1 in the door to hold the window up! 😂 Whilst I was tempted to knock the wood out, I resisted as I had a vision of the glass dropping and having a drafty drive for a few days! So, any suggestions as to what would make the glass drop? I'm assuming it's something to do with the mechanism, but without knowing what it should look like I'm kinda stuck! 1 Quote Link to post Share on other sites
C3peteo 13 Posted February 18 Report Share Posted February 18 Take the other door card off and you can then compare with a working set up. Quote Link to post Share on other sites
Unmutual 2 Posted February 18 Author Report Share Posted February 18 21 minutes ago, C3peteo said: Take the other door card off and you can then compare with a working set up. That ones the same! 😂 1 Quote Link to post Share on other sites
Rich 1,059 Posted February 18 Report Share Posted February 18 #6 is unmutual. See if you get the reference. Quote Link to post Share on other sites
Unmutual 2 Posted February 18 Author Report Share Posted February 18 59 minutes ago, Rich said: #6 is unmutual. See if you get the reference. Be seeing you Quote Link to post Share on other sites
Rich 1,059 Posted February 19 Report Share Posted February 19 Very nice Quote Link to post Share on other sites
