Tamsinwonder
Vw lupo passenger door leaking
Hi I have a vw lupo which is leaking through the passenger door. We've took the door cards off and poured water down the window and there's a lot of water coming through but we've changed the window seal and it's still doing the same. We are at a loss. Please help
Edited by Tamsinwonder
Edit for tags
Window seals are not perfect - there should be a sealing membrane behind the door cards that gets destroyed from maintenance - common VW problem not just on the Lupo
Make sure the door drain holes are clear as well. Also if you park on a steep enough slope the rain pools in the door sill and gets over the rubber seals.
