Arosa1980kid Posted January 20, 2020 Report Share Posted January 20, 2020 So last weekend I did a rear wiper delete, set off to work this morning and my front wipers wont switch off? Iv been told the stalk is a good contender, but im curious if iv messed something up, Quote Link to comment Share on other sites More sharing options...
LR5V Posted January 21, 2020 Report Share Posted January 21, 2020 That sounds like too much of a coincidence for the indicator stalk to fail - did you Seal up the loom and block the hose? i would plug the motor back in and see if it stops the fault Quote Link to comment Share on other sites More sharing options...
mk2 Posted January 21, 2020 Report Share Posted January 21, 2020 Yeah, you've got a short between the run on supply and the motor supply. You know, when you turn off the stalk before the wipers have reached their parking position- there's a switch inside the wiper motor always connected to ign +12v which ensures that the wipers return to their parked position, even after the wiper stalk has set them to off. Quote Link to comment Share on other sites More sharing options...
Arosa1980kid Posted January 30, 2020 Author Report Share Posted January 30, 2020 So I blocked the pipe, then wrapped all loom in tape, I decided to undo the negative battery lead to reset ecu? Anyways my wipers are sorted for the time being:/ Quote Link to comment Share on other sites More sharing options...
