mk2 Posted December 8, 2018 Report Share Posted December 8, 2018 I need to replace the driver's door hinges. Vdub want £22 each incl vat. No way. so I've been looking at other similar aged vdubs and they all appear to use the exact same hinge. I think. Bora/golf4/passat/lupo/audi.... but the parts numbers are all different. I'm not convinced. The correct Lupo number is 6E0831402C. on an Audi it's 8K0831402E on golfs it's 1J0831402C on passat 8E0831402C You get the picture. so, does anyone know which variant works out the best value for money? I'm sure they're all exactly the same. I've seen stuff on ebay going for about £5 each brand new, but, not a lupo part number. I'm not going to start ripping my mk4 golf to bits, just to find out. They do look exactly the same though... Anyone? Quote Link to comment Share on other sites More sharing options...
Rich Posted December 8, 2018 Report Share Posted December 8, 2018 A five door hinge will have had less weight on it. Ditto a GTi set. Theoretically, some fattie could have been leaning on it. Quote Link to comment Share on other sites More sharing options...
LR5V Posted December 8, 2018 Report Share Posted December 8, 2018 Are you looking for good used hinges from other models? I would take your old hinges on a day trip to a scrap yard to see what matches up, a lot will be dictated by how thick the door is and pivot point Quote Link to comment Share on other sites More sharing options...
mk2 Posted December 9, 2018 Author Report Share Posted December 9, 2018 Not sure what i'll be doing, but the drivers door moves up and down by about 10mm at the lock! Pin completely worn i reckon. So i'll try just swapping the lower one and see how it goes. The top one is known to be a tricky one to swap. Ideally brand new hinge. Just looking for cheap & new, as i could get a whole used steel door for £35.... Either way I'll need to do some painting. Quote Link to comment Share on other sites More sharing options...
PHILLIP JOHNSON Posted May 25, 2023 Report Share Posted May 25, 2023 AM LOOKING FOR A LUPO OFFSIDE FRONT LOWER HINGE VW PNO 6E0831402C CAN ANYONE HELP Quote Link to comment Share on other sites More sharing options...
