Will Cheyney Posted January 25, 2015 Report Share Posted January 25, 2015 (edited) Could someone guide me on how to change the standard Lupo GTI brake lines (front and rear, if different). I stupidly broke one off the rear caliper my mistake and thought I could use this as an opportunity to upgrade to braided lines all round.I couldn't see an obvious way to detach the rubber hose from the metal line (whole part seen in this picture). Thanks all! Edited January 26, 2015 by Will Cheyney Quote Link to comment Share on other sites More sharing options...
Silver! Posted January 25, 2015 Report Share Posted January 25, 2015 Rear beam to calliper is manufactured as one piece. So if you buy a braided set, you will get four pieces in a kit. 2 front and 2 rear: chasis to beam. beam to calliper: Either use the standard VW item, or get some made up. Quote Link to comment Share on other sites More sharing options...
Will Cheyney Posted January 25, 2015 Author Report Share Posted January 25, 2015 Thanks Ray.I've been looking at a set of these. 2 front, 2 rear.http://www.brake-lines.co.uk/hel-brake-lines-for-volkswagen-lupo-1.6-gti-2000.htmlAre you saying I'd have to use the existing line? How would the hoses attach?You can tell I've not done this before! Quote Link to comment Share on other sites More sharing options...
Silver! Posted January 25, 2015 Report Share Posted January 25, 2015 Yes, that is the kit I bought. There are two lines on the rear on each side: Chassis to beam; which you get in that kit Beam to calliper; which are copper pipe\rubber bonded. as I said, you will either need to use OE or get some custom made. I have OE with the HEL kit on mine and the braking is immense: Brembo G60 discs up front matching Brembo discs for the Lupo GTI on rear Tarox Strada pads all round Motul 5.1DOT fluid I paid someone to change mine, but there is a connection. Quote Link to comment Share on other sites More sharing options...
Will Cheyney Posted January 25, 2015 Author Report Share Posted January 25, 2015 (edited) Brilliant - massive help.It's the beam to caliper one that I've broken.So, I need to replace this with an OE one and use the HEL hose for the connection to the chassis to complete the upgrade. Shame there's always going to be some rubber present in the set up. Edited January 26, 2015 by Will Cheyney Quote Link to comment Share on other sites More sharing options...
Silver! Posted January 26, 2015 Report Share Posted January 26, 2015 It is. HEL reckon the OE ones are braided anyhow hence why they don't make it for the kit.But whilst they are stiffer than normal, Foxy cut his open to find it is not braided.You could get one made up by a "brake pipe maker"; Foxy made his own 'cause he had the flange kit. Quote Link to comment Share on other sites More sharing options...
James_VW Posted January 26, 2015 Report Share Posted January 26, 2015 Think I've read some where that the beam to calliper can be made from copper pipe and golf mk2/3 braided line's? Not to sure on this though! Quote Link to comment Share on other sites More sharing options...
Rich Posted January 26, 2015 Report Share Posted January 26, 2015 kunifer pipe, then a nipple to connect to mk2 golf mk4 caliper conversion hoses. Quote Link to comment Share on other sites More sharing options...
Silver! Posted January 26, 2015 Report Share Posted January 26, 2015 My VW Specialist thought of that as I bought the MK2\Mk4 conversion pipes, but he said he would need to fabricate a mount to hold it. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 26, 2015 Report Share Posted January 26, 2015 Yup, but fabricating a mount is simple.You can even use two jubliee clips to hold a mk2 one in place if you want to get functional/pikey. Quote Link to comment Share on other sites More sharing options...
Will Cheyney Posted January 29, 2015 Author Report Share Posted January 29, 2015 Just for the record, a new brake line from VW is £38. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 29, 2015 Report Share Posted January 29, 2015 £14 at ecp if you buy a mk4 golf one and just bend it a little. Quote Link to comment Share on other sites More sharing options...
Julesw Posted January 18, 2022 Report Share Posted January 18, 2022 Does anyone know the golf mark 4 part number? Quote Link to comment Share on other sites More sharing options...
