loopmuscle
gti conversions for dummies
33 posts in this topic
8v mounts are sat a few cm set further back, they were on my mk4 polo and the engine bays are the same
They weren't on my 1.0 Lupo.
Direct fit for both the Polo GTI and Lupo GTI engine I fitted to it.
aaha right must have slightly different mounts. on my polo the only mount different was the one on side with the cambelt
Thank you sooo much :) Gti conversion here i come :P
1.4s to AUB engine,
Let me see if i have this right
Whole Engine inc rad and coolant hoses
Loom (inside and out)
ECU
GearBox
I have ashley Manifold so that should fit
Anything else...
If Tigz or ArosaBinns or anybody reall fancy pming me then i would really appreciate that
I'm looking to do this conversion on my 1.0 with a friend.
Apart from the items listed above, what other bits do I need? For example exhaust, cooling system, engine mounts
Can I use the pedal box out of the polo the engine is coming from??
Cheers for all your help :)
congrats for providing so much info,2 fast questions if i got that right if there is no abs on your car(1.4 engine akq code) then after the convert you wont have clocks lighten?
and second way isnt there a way to use cable throttle body and original sport pedals?As long as i know there are cabled throttle body for 1.4 sport.The sport and the gtis t.b have the same diameter right?
If you're doing away with heating, electric windows, Central locking, Powersteering and ABS, does this conversion become easier?
We're also fitting the polo GTI clocks/dash
we've just stripped an entire polo GTI and have a lupo 1L
if you just don't bother with certain things and just chuck the loom into the car with the polo clocks it is pretty easy, however the whole conversion is pretty easy
