jamieirish Posted December 3, 2013 Report Share Posted December 3, 2013 Hey guy,Temp guage isn't working on my lupo e 1.4 16vI've replaced the blue temp sender and still no luck Any other ideas? Quote Link to comment Share on other sites More sharing options...
jamieirish Posted December 3, 2013 Author Report Share Posted December 3, 2013 GSF seem to bring up two temp sensors for my car (put reg in) blue which I replaced and then this onehttp://i183.photobucket.com/albums/x22/dadude01/Mobile%20Uploads/EC6D6FA2-5747-403F-9837-C8FD6409B3E1.pngWhere is that located because the second hole next to the blue one is blanked off Quote Link to comment Share on other sites More sharing options...
gatesy0093 Posted December 3, 2013 Report Share Posted December 3, 2013 ive just recently changed my temp sensor and noticed the blanked off valve, me and my dad just assumed it would be for higher spec models with A/C or something along those lines Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted December 3, 2013 Report Share Posted December 3, 2013 That photo is a temp sensor?Was it not that you replaced? Quote Link to comment Share on other sites More sharing options...
jamieirish Posted December 3, 2013 Author Report Share Posted December 3, 2013 This is what I'm talking aboutTwo ports left is blanked off and right has the blue sensor I replacedhttp://i183.photobucket.com/albums/x22/dadude01/Mobile%20Uploads/E371FBC2-70BF-45FE-8646-F9E257B9F637.jpgThere seems to be a sensor in the radiator which has wires to the fan and to the main loom, could it possibly be that one that feeds the dash information as well as the fan and the blue one in the thermostats just feeds the ECU? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted December 4, 2013 Report Share Posted December 4, 2013 If you can get hold of vagcom you can read the temp off th ECU, see if its getting any feed at all, to see if the gauge is dead rather than the sensor Quote Link to comment Share on other sites More sharing options...
Skezza Posted December 4, 2013 Report Share Posted December 4, 2013 If you can get hold of vagcom you can read the temp off th ECU, see if its getting any feed at all, to see if the gauge is dead rather than the sensor surely if the temp sensor feed to the ECU was dead, the car would be all over the place? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted December 4, 2013 Report Share Posted December 4, 2013 It will have a default setting that will let it run, just not at optimal performance/efficiencyI'm not sure if it would illuminate an engine check light if it didn't detect a signal from the sensor but the lack of post on here about it would suggest it doesn't. Quote Link to comment Share on other sites More sharing options...
