How to remove hazard button???
Hi everyone!
My partner's lupo's indicator has been having some problems...intermittent to say the least.
A new hazard button (with the indicator relay) is due tomorrow. Any ideas or advice before
i start? Havent worked on her lupo yet except changing bulbs, does it pop out or dashboard off jobbie?
http://s1352.photobucket.com/albums/q658/samax92/?action=view&current=image_zpsaa091f29.jpg
just to clarify thats for this style of hazard? some shops and breakers thought it was a different style button (rectangle button with red triangle sticker)
radio came out
metal headunit cage came out
storage tray underneath unclipped
torx screw at the far back of the hole comes out(where the stereo sits)
two torx just inside the hole, left and right, came out
entire centre console unclips at the top, pivots slightly towards you then all comes out upwards
remove the hazard button etc etc
you probably could just do it without the removing torx screws but not without compromising the plastic clips all around. from experience on my old clios, breaking plastic clips and trim is dangerously easy
turns out it hasnt fixed the indicator. just seems like a bad connection on the actual stalk. put the old hazard back in.
brand new hazard switch for sale - £10. RRP £23.
  • 10 years later...
