Tom_C Posted February 8, 2013 Report Share Posted February 8, 2013 Hey guys..So When I bought my car my drivers side window was very temperamental worked when wanted too, then suddenly stopped working altogether. Switch clicked but window never went down.Today attempted to see if I can fix the problem myself, took door card off and switch out and gave the insides of the switch a clean and re-installed it.Now I plugged it back in and once again didn't work, however I swapped the passenger wiring around with drivers side and it worked.What I'm asking is if anyone has a solution on how to fix this, Is this a wiring issue and will have to buy a new wiring loom or will it be a miss connection somewhere??Many thanks, Tom Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted February 8, 2013 Report Share Posted February 8, 2013 Have a look inside the rubber grommet that runs from the a-pillar to the door, there could be a broken wire in there, usually the fattest cables! Quote Link to comment Share on other sites More sharing options...
Pete91 Posted February 8, 2013 Report Share Posted February 8, 2013 Try what lupogtiboy said first.If that doesn't work then you can pick up the whole mechanism pretty cheap (paid £20 for mine from a scrappy) and it's pretty straight forward to fit. Quote Link to comment Share on other sites More sharing options...
