Aiyame Posted October 7, 2012 Report Share Posted October 7, 2012 hi quick question i've just had 4 wheel alignment done on my car to get it through its mot they had to lift it back up tho to do it will it knock it all back out of line if i readjust it back down to minimum again cheers for reading Quote Link to comment Share on other sites More sharing options...
davidelliott294 Posted October 7, 2012 Report Share Posted October 7, 2012 (edited) Yes it will need to be re-tracked if you go lower - that's if you tracked it when it was raised, if not then try to return the threads to it's previous point and it will be fine. I'm pretty sure tracking doesn't need to be done for a MOT. Edited October 7, 2012 by davidelliott294 Quote Link to comment Share on other sites More sharing options...
Ashh Posted October 7, 2012 Report Share Posted October 7, 2012 If its on coilovers just raise it for MOT then wind backdown to roughly where it was. The main killer of tyres is toe in/out... Which won't be changed by adjusting coilovers. But camber will be changed with the height. If you undo the top mount, or the two that attach the strut to hub etc, then you need tracking done. If not, I wouldn't bother Quote Link to comment Share on other sites More sharing options...
Aiyame Posted October 7, 2012 Author Report Share Posted October 7, 2012 Ye it's on coilies I'll just wind it back down then cheers Quote Link to comment Share on other sites More sharing options...
joshuaar Posted October 7, 2012 Report Share Posted October 7, 2012 how come you needed tracking doing for an mot? as said above i don't think tracking comes under the mot Quote Link to comment Share on other sites More sharing options...
davidelliott294 Posted October 7, 2012 Report Share Posted October 7, 2012 Nah it most definitely doesn't. If you got it tracked when it was raised then you will need to get it tracked when you lower it. If it was tracked then raised try to return the rings down to the threads it was on before you raised it. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted October 7, 2012 Report Share Posted October 7, 2012 'Tracking' normally just refers to toe adjustment.In raising/lowering the car using the threads you do not alter the toe so it will not need adjusting.The camber will change, but as long as its equal both sides it will be fine.Where did you take it out of interest? Quote Link to comment Share on other sites More sharing options...
Aiyame Posted October 7, 2012 Author Report Share Posted October 7, 2012 Took it Ivc in Leeds Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted October 7, 2012 Report Share Posted October 7, 2012 I dont think he needed it track for the MOT. Add punctuation into the first post and I think it's supposed to read;"hi, quick question, i've just had 4 wheel alignment done on my car. To get it through its mot they had to lift it back up, tho to do it will it knock it all back out of line if i readjust it back down to minimum again? cheers for reading" 2 Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted October 7, 2012 Report Share Posted October 7, 2012 Took it Ivc in LeedsI took mine there once.Never went back Quote Link to comment Share on other sites More sharing options...
Pete91 Posted October 7, 2012 Report Share Posted October 7, 2012 I dont think he needed it track for the MOT. Add punctuation into the first post and I think it's supposed to read;"hi, quick question, i've just had 4 wheel alignment done on my car. To get it through its mot they had to lift it back up, tho to do it will it knock it all back out of line if i readjust it back down to minimum again? cheers for reading"Hahaha that's awesome. The first post makes so much more sense now lol Quote Link to comment Share on other sites More sharing options...
joshuaar Posted October 7, 2012 Report Share Posted October 7, 2012 I dont think he needed it track for the MOT. Add punctuation into the first post and I think it's supposed to read;"hi, quick question, i've just had 4 wheel alignment done on my car. To get it through its mot they had to lift it back up, tho to do it will it knock it all back out of line if i readjust it back down to minimum again? cheers for reading"Aah, that makes much more sense Quote Link to comment Share on other sites More sharing options...
davidelliott294 Posted October 7, 2012 Report Share Posted October 7, 2012 'Tracking' normally just refers to toe adjustment.In raising/lowering the car using the threads you do not alter the toe so it will not need adjusting.The camber will change, but as long as its equal both sides it will be fine.Where did you take it out of interest?So because he has raised it up and down does that not mean he needs to get his tracking done?From what you are saying, I understand that he doesn't. Is that right? I'm lead to believe he does? Quote Link to comment Share on other sites More sharing options...
