ElZ 16v Posted July 17, 2012 Report Share Posted July 17, 2012 i drive a mk1 arosarecently removed helpers from the front suspension an fully wound it downneedless to say its got very very bouncy if doing over 50mph an apply the brakes it feels as if its skippingis there anything i can do to soften the bouncing ..please do not comment saying thats what helpers do which i realise but is there anything else i can do as coming out of the seat constanty isnt comfy ahacheers! Quote Link to comment Share on other sites More sharing options...
JoeA Posted July 17, 2012 Report Share Posted July 17, 2012 spring assisters. Quote Link to comment Share on other sites More sharing options...
ElZ 16v Posted July 17, 2012 Author Report Share Posted July 17, 2012 yea i read that and googled then could you explain which brand and where i get them from an il be eternally greatful i dis google it but it said there for towing caravans? aha cheers! Quote Link to comment Share on other sites More sharing options...
JoeA Posted July 17, 2012 Report Share Posted July 17, 2012 Yeah are made for that as caravans make your car bouncy due to extra rear end weight. ask Mitch with the blue tdi Quote Link to comment Share on other sites More sharing options...
joshuaar Posted July 17, 2012 Report Share Posted July 17, 2012 Surely the spring assisters will make the wheel skipping even worse? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted July 17, 2012 Report Share Posted July 17, 2012 What suspension do you have? Quote Link to comment Share on other sites More sharing options...
ElZ 16v Posted July 17, 2012 Author Report Share Posted July 17, 2012 Yeah are made for that as caravans make your car bouncy due to extra rear end weight. ask Mitch with the blue tdi cheers il do that What suspension do you have? Ta technix with helpers removed and wound right down Quote Link to comment Share on other sites More sharing options...
ElZ 16v Posted July 29, 2012 Author Report Share Posted July 29, 2012 can someone help mee? even bouncier now as its lower as i put my raceland springs inplace of the Ta springsdo i just buy any old spring assistor? Quote Link to comment Share on other sites More sharing options...
Thooooom Posted July 29, 2012 Report Share Posted July 29, 2012 Do you mean bouncy like soft suspension? Or bouncy like rock solid and you hit the bumps in the road? I run TA's without helpers and they're like rocks. Quote Link to comment Share on other sites More sharing options...
ElZ 16v Posted July 29, 2012 Author Report Share Posted July 29, 2012 hmm i hot a tiny little bump it just carres on bouncing for ages but yes hit a big bump an im out the seat very regular!been told spring assistors for towing caravans help alot? Quote Link to comment Share on other sites More sharing options...
Thooooom Posted July 29, 2012 Report Share Posted July 29, 2012 Yeah I've heard that, but obviously only for the rear. I think mine are fine, they're rock hard but if they weren't I wouldn't be able to be as low so. Quote Link to comment Share on other sites More sharing options...
ElZ 16v Posted July 29, 2012 Author Report Share Posted July 29, 2012 im more concerend about the front bouncing alot but guess il have to live with it or buy different coilovers Quote Link to comment Share on other sites More sharing options...
Owen33 Posted July 29, 2012 Report Share Posted July 29, 2012 Just be because it's that far down and constantly sat on the bump stops.If by wound all the way down you actually mean bottom of the threads then chances are the springs not even in contact with upper support?Will be able to wind the adjusters up a good inch and it wont make a difference to the ride height Just what I've experienced so might not be correct in your case Quote Link to comment Share on other sites More sharing options...
ElZ 16v Posted July 29, 2012 Author Report Share Posted July 29, 2012 yep when fully wound down on the raceland springs the suspension quite literally didnt move it was only tyre flexing because it was because the shock was constantly bottomed out i think wound it up a few turns the suspension actually works a bit now aha Quote Link to comment Share on other sites More sharing options...
