Baker_888 Posted July 14, 2012 Report Share Posted July 14, 2012 Hi guysIve been driving my Arosa 1.0 for just over a week now, and over the last 2 days, 1st, 2nd and 3rd gear I have to force them in, with the clutch all the way down to the floor. and whenever i put it in reverse it will crunch without fail! Just wondering if there is anything i should look out for? anyway of fixing the problem? Quote Link to comment Share on other sites More sharing options...
craigg!! Posted July 14, 2012 Report Share Posted July 14, 2012 Sounds like the pedal box. Search the forum there is loads of topics about this. Very common fault. Quote Link to comment Share on other sites More sharing options...
craigg!! Posted July 14, 2012 Report Share Posted July 14, 2012 And because I'm a nice guy...http://forums.clublupo.co.uk/index.php?showtopic=33400&pid=843370&st=160entry843370 Quote Link to comment Share on other sites More sharing options...
JGTTDI2 Posted July 18, 2012 Report Share Posted July 18, 2012 I had the same problem with my arosa 1.0 a few weeks ago and i thought it was the pedal box too, it always crunched into gears etc then one day i heard a snap and thought the pedal box had failed and it turned out to be the clutch cable that snapped so i would check that.Hope that helps. Quote Link to comment Share on other sites More sharing options...
bowers155 Posted July 18, 2012 Report Share Posted July 18, 2012 adjust clutch cables and gear linkages! on my old 1.0 one of the bolts came loose out of the linkage! Quote Link to comment Share on other sites More sharing options...
Gibbo VW Posted July 23, 2012 Report Share Posted July 23, 2012 I had stiff gears, mainly going in to reverse and some of the other extreme gears like 1st and 5th on my TDi. I found that the gear linkages needed adjusting, but make sure you free off the threaded rod section beside the twist lock as they sometimes stick as well. Quote Link to comment Share on other sites More sharing options...
