8ballvmax Posted April 14, 2012 Report Share Posted April 14, 2012 ok daft question but are these the same enines?? and is it a "simple" case of just swapping engine and box or is it more involved on the electrical side ,like ECU etc.... ford escorts were so much simpler lol Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted April 14, 2012 Report Share Posted April 14, 2012 They have different gearboxes and clutches. Which do you have? Quote Link to comment Share on other sites More sharing options...
JoeA Posted April 14, 2012 Report Share Posted April 14, 2012 I think he wants to put a 1.6 in his 1.4 lupo Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted April 14, 2012 Report Share Posted April 14, 2012 Oh sorry, I thought he wanted to put a Polo GTI engine in a Lupo GTI or vice-versa? The post doesnt really make sense Quote Link to comment Share on other sites More sharing options...
JoeA Posted April 14, 2012 Report Share Posted April 14, 2012 Yeah we do need more info..... Quote Link to comment Share on other sites More sharing options...
Blaine Posted May 8, 2012 Report Share Posted May 8, 2012 gonna drag thid thread back up..Puting a polo GTI into a 1.4what is involved in it? asin do they have the same engine/gearbox mounts and would you have to fit a hydraulic pedal box or is the polo a cable clutch?thanks Blaine Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted May 8, 2012 Report Share Posted May 8, 2012 Polo is cable Quote Link to comment Share on other sites More sharing options...
Blaine Posted May 8, 2012 Report Share Posted May 8, 2012 Polo is cablethat would save some work then do you know of any build threads with this converstion? Quote Link to comment Share on other sites More sharing options...
dubsy Posted May 8, 2012 Report Share Posted May 8, 2012 what do you need to know? Quote Link to comment Share on other sites More sharing options...
Blaine Posted May 8, 2012 Report Share Posted May 8, 2012 aha i see you have done this urrm lots lolif i was to do it i think the best option for me would be to get a 6n2 gti so everyhting is there engine loom,interior loom,ecu ect...i guess i would need to make the exhaust myself..mines a 1.4sare engine mounts the same? so will the engine /gearbox just bolt in?do you need the gti radiator if so was this easy to mount?do you need gti hubs for the drive shafts?can i use my fuel pump?are the clutch and gear linkage easy to adapt?cheers Blaine Quote Link to comment Share on other sites More sharing options...
dubsy Posted May 8, 2012 Report Share Posted May 8, 2012 right engine and gearbox mounts are the same, you dont need the gti radiator use your own, hubs and driveshfts are the same i changed the fuel pump for the gti one as its a better spec and the cluch and gear linkage are the same, only differences are if your running drive by wire youll have to convert to flyby wire so youll need the polo gti gas pedal, as for the looms you will need the rear loom( important due to the immobiliser ) and engine bay loom, however the plugs on the polo rear loom are different to the lupo, for the central locking and sun roof( if you have one), so the lupo plusgs will have to be spliced onto the polo loom, this also applies to the engine bay loom for the headlights the lupo plugs will have to be spliced onto the polo loom if your keeping your original key you will then have to have this reprogrammed to the polo ecu( i did this ) otherwise you need to use the polo ignition barrel and key but that means having 2 separate keys for doors and ignitionhope this helps, carl Quote Link to comment Share on other sites More sharing options...
Blaine Posted May 8, 2012 Report Share Posted May 8, 2012 Thanks for the helpso from a mechanical point of view it's just a straight swap 1.4 out GTI in then the hard part is the wiring.i was pretty sure my car is flyby tbh Quote Link to comment Share on other sites More sharing options...
dubsy Posted May 9, 2012 Report Share Posted May 9, 2012 That's correct Quote Link to comment Share on other sites More sharing options...
Blaine Posted May 9, 2012 Report Share Posted May 9, 2012 i think this could be on the cards at some point This one is up for £900 because the paintwork is **** http://www.pistonheads.com/sales/3880169.htm then spend abit of money on cambelst kit and clutch and i'm laughin Quote Link to comment Share on other sites More sharing options...
Dogbot Posted May 31, 2012 Report Share Posted May 31, 2012 (edited) The only thing I would say differently to dubsy is to use the bigger rad, if you've got it you may aswell, just need to cut out the closed half of the cowl. an you can tak the chip from the donor cars key an put it in your original key, no need for recoding then, it just lifts from one key to another, also I found it far less work to splice in the polo engine and ecu loom into th lupo loom, personal preference tho I believe on that front Edited June 1, 2012 by Dogbot Quote Link to comment Share on other sites More sharing options...
huzzy134 Posted January 30, 2014 Report Share Posted January 30, 2014 (edited) The only thing I would say differently to dubsy is to use the bigger rad, if you've got it you may aswell, just need to cut out the closed half of the cowl. an you can tak the chip from the donor cars key an put it in your original key, no need for recoding then, it just lifts from one key to another, also I found it far less work to splice in the polo engine and ecu loom into th lupo loom, personal preference tho I believe on that frontHow hard would you say that is on a scale of one to ten ? The wiring sorry Edited January 30, 2014 by huzzy134 Quote Link to comment Share on other sites More sharing options...
