sharpelupo
meguiars
hi guys taken my rear badges off but it has left an outline of the badges i bought some meguiars ultimate compound to try and get rid of them will this work if not any ideas of something better? iv used AG intensive tar remover to get rid of the stickey rubbish left
Is it where its faded or because of contaminants on the surface?
Tape up a square so the area your gonna be working on is inside the tape line so you have a really small set length and just attack the area with your applicator abd Megs UC. You might need to give it multiple hits.
and finish the area with something milder like lime prime to remove any swirls the UC may leave behind, i found UC left a lot of maaring on an astra vxr i corrected but then again the paint is very soft on vaux
i used a little hot water and a thin bit of laminate did the job then just polish up
