smileysara Posted March 15, 2012 Report Share Posted March 15, 2012 hi hope you guys can help had a look through the forum and cant find anything to help heres the problem during warmer weather i drive to town am out car for little while but when i get back in it dont wanna startmy other half got me (saying i need to learn how) to change air filter(was caked in oil looked like never been replaced) didnt help so then changed plugs (with recomended 1s) leasds and then coil packseemed fine durning the winter am guessing the cold helped but now as getting warmer starting to do it again and getting anoyin as am stuck until can get it sorted also when it dose start theres a strong petrol smell to top it off sometimes it will fire up only to cough and diewere stuck for the cause of the problem could it be air temp sensor or cold start sensor problem (other half had same problem on his old civic turned out to be sensor)cheers for lookingoh its a 1.4 75hp lupo cant remember the engine code sorry Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted March 15, 2012 Report Share Posted March 15, 2012 Does your temperature gauge work properly? Quote Link to comment Share on other sites More sharing options...
smileysara Posted March 15, 2012 Author Report Share Posted March 15, 2012 everything is fine all guages work fine. now telling me needs a service but been having this prob before tht came up only other probs is windows which is runners sticking n dodgy switches(been fixed once .) Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted March 15, 2012 Report Share Posted March 15, 2012 Well Im tempted to say its some kind of fuelling issue, but given the apparent lack of servicing that this car has had it could be a multitude of things.Scan it for fault codes, see what it throws up. Quote Link to comment Share on other sites More sharing options...
smileysara Posted March 15, 2012 Author Report Share Posted March 15, 2012 its been serviced by other half oil changes plugs when needed n all that gonna look at fuel filter come payday...did take it to a garage did a scan for codes and found nothing and typically it started fine for the whole day they had it thanx for help tho Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted March 15, 2012 Report Share Posted March 15, 2012 I would be tempted to change the coolant temperature sensor, as it sounds like it is flooding itself Quote Link to comment Share on other sites More sharing options...
looploop91 Posted March 15, 2012 Report Share Posted March 15, 2012 Does your temperature gauge work properly?Love how many times you've asked this question in the last few hours haha..... seams to be linked to quite a few problems Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted March 15, 2012 Report Share Posted March 15, 2012 I dont even read the fisrt post anymore, just past that into the reply box! Quote Link to comment Share on other sites More sharing options...
smileysara Posted March 19, 2012 Author Report Share Posted March 19, 2012 my other half had a thought could this be cos of piston ring problems or maybe headgasket problems? was jus a thought n thought it would be a gd idea to run it past some ppl with a little more experence with vw's lol Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted March 19, 2012 Report Share Posted March 19, 2012 Wont be headgasket. If your piston rings were shot to the point where it wont even start you would be burning oil like there was no tomorrow, is it? Quote Link to comment Share on other sites More sharing options...
smileysara Posted March 20, 2012 Author Report Share Posted March 20, 2012 not tht i know of and no blue smoke was jus thoughts wanna tick off as many things as pos before i bite bullet n try a garage again... will do compression test at wknd jus to be sure then will be onto trying sensors and taking a look at earthing wires jus incase of weak sparkstill think its a sensor either air temp or cold start sensor Quote Link to comment Share on other sites More sharing options...
Owen33 Posted March 20, 2012 Report Share Posted March 20, 2012 I'd defintely try water temp sensor, my brothers GTi and mine both had these symptoms. any slight temperture still in the engine I.e if the temp gauge shows above 70 it electrically doesn't open the throttle, My guessing yours might be complete flyby wire? The GTi was any it expierenced it much worse than mine... Just a suggestion, but for the price of £5 on ebay its worth a try Quote Link to comment Share on other sites More sharing options...
smileysara Posted March 21, 2012 Author Report Share Posted March 21, 2012 for 5 quid ill get tht the wknd nice 1 cheers fingers crossed Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted March 21, 2012 Report Share Posted March 21, 2012 I would recommend getting genuine sensors, with cheapo ones you can never really rule them out Quote Link to comment Share on other sites More sharing options...
smileysara Posted March 22, 2012 Author Report Share Posted March 22, 2012 can any1 recomend a gd place to get lupo parts from like sensors and stuff ebay can be fairly hit and misscheers Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted March 22, 2012 Report Share Posted March 22, 2012 There is only one - Lupoboz on here.See his thread in the traders section - 'Genuine VW Parts' Quote Link to comment Share on other sites More sharing options...
Lupoboz Posted March 23, 2012 Report Share Posted March 23, 2012 Hi Smileysara, I would say that you are experiencing over fuelling problems in the warmer weather. I'd replace the coolant temperature sensor, as this sensor has a number of fuctions. One of the main ones being, that it sends the water temperature to the engine ECU (the electrical brain) If this sensor is faulty, the sensor can send incorrect info to the ECU, resulting in problems of this nature. (i.e. over fuelling, rough running, poor idling etc)I take it that the fuel consumption has been somewhat high? I'd try a sensor first with a new sealing ring. Then if the problem persists ask your local garage to clean the throttle body out, or you can attempt this yourself, although it is a rather delecate job to carry out. I can go into further detail about this if you wish.Let me know if so, as it get's a bit technical lol. If you'd like to PM me with your Lupo's registration number, l'll see how much a new coolant temperature sensor is for you, as they do differ between the models.Regards, Dale.(Thanks Defcon5) Quote Link to comment Share on other sites More sharing options...
smileysara Posted March 25, 2012 Author Report Share Posted March 25, 2012 cheers lupoboz we have a coolant temp sensor on way hopefully will sort it if not may hit ya up for some more info on cleaning the tb as other half will do tht after sorting the dam windows thamx again every1 hopefully this works Quote Link to comment Share on other sites More sharing options...
