1.4Josh Posted January 2, 2012 Report Share Posted January 2, 2012 Everytime it rains the next morning my mat seems to be soaked! I have a sunroof but I can never see where it is leaking from.Any ideas or has anyone had the same problem?? Thanks Quote Link to comment Share on other sites More sharing options...
scirocco Posted January 2, 2012 Report Share Posted January 2, 2012 i get the same problem think mine might be coming in rear hatch seal and running back into car and down into rear footwell drivers side Quote Link to comment Share on other sites More sharing options...
lupo1.0se Posted January 3, 2012 Report Share Posted January 3, 2012 Only just saw this thread.I have similar issues but on the passenger side. Have you checked the drain pipe on side of the car where water goes down, it sounds like they might be blocked.If you unscrew the panel below the wipers this should give you access to the passenger side. The drivers side does look a bit trickier but you may be able to get your hand in there.Hope this helps. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 3, 2012 Report Share Posted January 3, 2012 You've all got leaks. Quote Link to comment Share on other sites More sharing options...
