Dannii1491 0 Posted July 8, 2011 Report Share Posted July 8, 2011 i have been searching and searching this forum to get information about offsets but tbh im just getting more confused,so im just going to ask the usual question.... will they fit? (15x8" 4x100 et0) the alloys are Rota Aleica. Quote Link to post Share on other sites
scotty_82 378 Posted July 8, 2011 Report Share Posted July 8, 2011 Yes if you have arches rolled and pulled a bit and you run some serious stretch, even then it will probably still catch. Quote Link to post Share on other sites
heartagram 44 Posted July 9, 2011 Report Share Posted July 9, 2011 These are ET10. 165/50/15. Took a lot of pulling. Quote Link to post Share on other sites
marcyd 5 Posted November 14, 2013 Report Share Posted November 14, 2013 What about the same wheel on a lupo gti been as the slightly wider as standard ? Quote Link to post Share on other sites
EaRNi! 11 Posted December 10, 2013 Report Share Posted December 10, 2013 It depends how low you are. I'm running 15x7 ET-7 (yes minus 7) and they fit really nice on a gti. By my calculations these will stick out 5.2mm more.Can someone correct me if my sums are wrong? Quote Link to post Share on other sites
Pete91 284 Posted December 10, 2013 Report Share Posted December 10, 2013 I work it out as being 19.7mm more poke Quote Link to post Share on other sites
EaRNi! 11 Posted December 10, 2013 Report Share Posted December 10, 2013 If a wheel is 1" wider then doesn't it add 0.5" each side rather than 1" on the front If the offset is the same? Quote Link to post Share on other sites
Pete91 284 Posted December 11, 2013 Report Share Posted December 11, 2013 15x7 et -77x25.4 = 177.8/2 = 88.9-7 = 81.9mm distance sticking out from the hub15x8 et 08x25.4 = 203.2/2 = 101.6mm distance sticking out from the hubSo the 8's will stick out 20mm further than the 7's Quote Link to post Share on other sites
EaRNi! 11 Posted December 11, 2013 Report Share Posted December 11, 2013 You did minus 7 whereas it should be plus 7.Otherwise the normal offset would be minus 30odd. Quote Link to post Share on other sites
Pete91 284 Posted December 11, 2013 Report Share Posted December 11, 2013 **** my bad. It'll be 5.7 then. The difference is just a rounding error Quote Link to post Share on other sites
