Ashh Posted June 7, 2011 Report Share Posted June 7, 2011 I've got some Meg's metal polish from work for free because the lid had a crack so it was free to first dibs!Basically im after polishing my engine to make it a little more attractive? Just after an idiots guide on how to polish it up, starting from its current rather dull looking state! Or if its even possible?Cheers, Ash! Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted June 7, 2011 Report Share Posted June 7, 2011 That will be a nightmare of a job Quote Link to comment Share on other sites More sharing options...
Ashh Posted June 7, 2011 Author Report Share Posted June 7, 2011 That will be a nightmare of a jobThat bad? I'm such a novice haha Quote Link to comment Share on other sites More sharing options...
BEP51 Posted June 7, 2011 Report Share Posted June 7, 2011 (edited) if u keep the cover on u can polish the two visible strips without much hassle. just start with a coarse sandpaper, then keep going finer going over all the previous score marks before going to a finer paper, eventually wet and dry, then just rub in the polish. Edited June 7, 2011 by BEP51 Quote Link to comment Share on other sites More sharing options...
Ashh Posted June 7, 2011 Author Report Share Posted June 7, 2011 if u keep the cover on u can polish the two visible strips without much hassle. just start with a course sandpaper, then keep going finer going over all the previous score marks before going to a finer paper, eventually wet and dry, then just rub in the polish.That is all i was after doing, i didnt want to do the whole thing haha, what level paper should i start on? Quote Link to comment Share on other sites More sharing options...
BEP51 Posted June 7, 2011 Report Share Posted June 7, 2011 (edited) start with the most coarse u can get hold of, if u cant get really coarse stuff, just use the roughest u can find, just will take longer with finer papers. Edited June 7, 2011 by BEP51 Quote Link to comment Share on other sites More sharing options...
99hjhm Posted June 8, 2011 Report Share Posted June 8, 2011 Do you mean the cam cover? Quote Link to comment Share on other sites More sharing options...
BEP51 Posted June 8, 2011 Report Share Posted June 8, 2011 he does, yes. Quote Link to comment Share on other sites More sharing options...
Ashley Posted June 8, 2011 Report Share Posted June 8, 2011 To do the cam cover I doubt you will need to start with the coarsest grade you can get. I would recommend starting at P120, work your way up to P2000 / P2500 and then work the polish. It's simple .Ashley Quote Link to comment Share on other sites More sharing options...
Davesport Posted January 26, 2012 Report Share Posted January 26, 2012 I done this it took along time but worth it in the end if doing this by hand it took me like 2 hours each strip that was taking my time mind Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted January 26, 2012 Report Share Posted January 26, 2012 like this?few hours working through different stages of wet and dry, then polish. autosol out be a better polish to use IMO as its coarser Quote Link to comment Share on other sites More sharing options...
