Lupo-Joe Posted April 27, 2011 Report Share Posted April 27, 2011 (edited) People i want to cleaning up my engine bay and try make it look real nice(with out removing the engine), however im a bit apprehensive on whether there is areas where i should be really careful? How have you gone about it and what works best for you really?I would be really gratefully for any tips as im keen to do it!Thanks Members! Edited April 27, 2011 by Lupo-Joe Quote Link to comment Share on other sites More sharing options...
mat.m. Posted April 27, 2011 Report Share Posted April 27, 2011 A Steam cleaner works very well at removing 'gunk'Work on a small area at a timeAvoid getting 'soap' near the aux belt and rollersMeg's Super Degreaser is a very good product to useHope that helps Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted April 27, 2011 Report Share Posted April 27, 2011 i found it easier with no front end, other find it even easier with no engine in!Tardis is a good product i found from removing all the dirt, sure others will agree Quote Link to comment Share on other sites More sharing options...
rosiearosa Posted April 27, 2011 Report Share Posted April 27, 2011 Tardis or APC should do it. Highly recommend steam. Have known a mate just snowfoam an enginebay before now! Not sure you'd get away with that on summat modern tho....... Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted April 27, 2011 Report Share Posted April 27, 2011 Cover the electrics with plastic bags, and spray all the connections you can see with WD40 before and after cleaning. Dont use a pressure washer Quote Link to comment Share on other sites More sharing options...
Big Jase Posted April 27, 2011 Report Share Posted April 27, 2011 Instead of wd40 use some dielectric grease! Available from maplins i just hosed my engine bay at the weekend Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted April 27, 2011 Report Share Posted April 27, 2011 surely just hosing it does f all? the dirt and grime in the chassis legs needs a proper good scrub Quote Link to comment Share on other sites More sharing options...
little rich Posted April 27, 2011 Report Share Posted April 27, 2011 ^ agree there, I have no engine in so it should be easy? ...have about 5mm crud in the chassis legs etc and its a right mission! Just keep your bonnet shut so no one sees the ****e Quote Link to comment Share on other sites More sharing options...
rosiearosa Posted April 27, 2011 Report Share Posted April 27, 2011 If ya got no engine in thn blast it with snow foam Quote Link to comment Share on other sites More sharing options...
little rich Posted April 27, 2011 Report Share Posted April 27, 2011 Snow foam is ****.Elbo grease and a scrubbing brush is what you need! and motivation, I only have the scrubbing brush Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted April 27, 2011 Report Share Posted April 27, 2011 mix the snow foam with tardis!... leave for a few days and then im sure the dirt will be come off, maybe the paint as well though Quote Link to comment Share on other sites More sharing options...
Big Jase Posted April 27, 2011 Report Share Posted April 27, 2011 surely just hosing it does f all? the dirt and grime in the chassis legs needs a proper good scrubI ment hosing as the use of waterI used a paintbrush and some APC to clean it then hosed off Quote Link to comment Share on other sites More sharing options...
Lupo-Joe Posted April 28, 2011 Author Report Share Posted April 28, 2011 Thanks people sounding good! will buy my sell some APC and have a scrub Cheers Quote Link to comment Share on other sites More sharing options...
