Arosa servicing
`PAFC-BUCKY`
My "better half's" Seat Arosa (W reg) is due for its 40,000 mile service. She rang the local Seat dealer to get a quote and once she gotten back off the floor she told be it would cost £230!!! She was told that it was a major service and that they would explain once she delivered the car what was to be done. But can anyone shed some light as to what needs to be done to cost so much? As the car is out of warrenty we have asked a local garage for a quote as well - getting back to us later today.
I have a ZR160 and the most I need to pay for a service is around £170.
many thanks
They check the spark plugs (you can tell them to not check these)
They check the fluid levels (again, no need for them to do)
Just tell them you want the minum 40k service.
I think LinconshireLupoGTi knocked £100 (ish) off the price of his 40k service doing this.
servicing costs over 3 years (36000 miles)for a 1.4 lupo is quoted as £572, the MG ZR160 didn't have any figures but my Ibiza Cupra is quoted as £952 over the same period so it seems reasonable. Lupo gti is £871. You'll find the service details and pence per mile etc. under the car specification at www.watcar.co.uk.
always worth shopping around, bound to be anoterh seat dealer within travling distance that might giv ea better quote. Labour rates can vary hugely depending on where you go.
don't go to Seat! i would go to my local garage or some place like `Quick-fit` as iv just had my 20K done by Seat and they charged me for things like screen wash even when my tank was full! i had to give it to Seat this time as the warranty work can only be done by them, am sure all car garages are like this however.
if they topped it up but couldn't put in a whole bottle of screen was they usually leave the rest in the car for you, can ask them not to fill it up if you want though. Can also bring allong your won oil and they will use that, can make it a lot cheaper for just oil change services.
To be fair, if you go by what ELSA (the VW Maintanence manual) says, there is a fair old amount to do:
Work to be completed
Page
- Front and rear lights, turn signals, hazard warning lights: Check function
- Interior lighting, cigarette lighter, warning lamps and horn: Check function
- Driver's and front passenger's airbag: Visual check of airbag units for exterior damage
61
- Windscreen wash/wipe system and headlight washer system: Check function and settings
63
- Windscreen wiper blades: Check for damage; Check park position, adjust if necessary; If wiper blades judder: Check rest angle, adjust if necessary.
70
- `Self-diagnosis`: Interrogate fault memory of all systems
75
- Direct shift1): Perform basic settings
83
Page
- Service interval display: Reset
83
- Grease door arrester and securing pins
124
- Sliding sunroof: Check function, clean guide rails and spray with grease G 052 778
125
- Folding fabric sunroof: Grease guide rails
125
- Battery: Check
39
- Engine and components in engine compartment (from above): Visual check for leaks and damage
126
- Windscreen wash/wipe system: `Top-up` with fluid G 052 164
63
- Cooling system: Check coolant level and frost protection and add coolant/`anti-freeze` if necessary
127
- Spark plugs: Renew - spark plug designation seeEmission test binder -
(every 4 years or at 60,000 km (approx. 40,000 miles) whichever occurs first)
144
- Air cleaner: Clean housing and replace filter element
(engine codes AKU, AMF, ANY, ARR, AYZ all 72 months or every 60,000 km (approx. 40,000 miles) whichever occurs first)
131
- Air cleaner: Clean housing and renew filter element
(all engines except engine codes AKU, AMF, ANY, ARR, AYZ every 3 years or every 90,000 km (approx. 60,000 miles) whichever occurs first)
131
- Power assisted steering: Check oil level, if necessary `top-up` hydraulic oil
(every 60,000 km (approx. 40,000 miles))
156
- Fuel filter: Renew
(every 60,000 km (approx. 40,000 miles) on vehicles with diesel engine)
160
- Fuel filter: Drain water
(Diesel engine)
164
Page
- Dust and pollen filter: Replace filter element
167
- Toothed belt: Renew / additional work as a separate charge!
- every 60,000 km (approx. 40,000 miles): diesel engines with engine code AKU ▸ 2000 (▸Y)
- every 90,000 km (approx. 60,000 miles): diesel engines with engine code AKU 2001 ▸ (1 ▸)
173
- Toothed belt and toothed belt tensioning roller: Renew / additional work as a separate charge!
- every 60,000 km (approx. 40,000 miles): diesel engine with engine code ANY ▸ 2000 (▸Y)
- every 90,000 km (approx. 60,000 miles): diesel engine with engine codes ANY, AYZ 2001 ▸ (1 ▸)
173
- every 60,000 km (approx. 40,000 miles): diesel engine with engine code AMF ▸ 2000 (▸Y)
- every 90,000 km (approx. 60,000 miles): diesel engine with engine code AMF 2001 ▸(1 ▸)
173
- Toothed belt: Check wear
(TDI / SDI engines ▸ 2000 (▸ Y) with engine codes AKU, AMF, ANY)
169
- Toothed belt for camshaft drive: Check
(`4-cylinder` - petrol engine: At 90,000 km/60,000 miles, thereafter every 30,000 km/20,000 miles)
171
- Engine oil: Drain or extract; Renew oil filter (Inspection service with oil change).
174
- Engine and components in engine compartment (from below): Visual check for leaks and damage
126
- Ribbed belt: Check condition
185
- Gearbox, final drive and joint protective bellows/boots: Visual check for leaks and damage
186
- Direct shift1): Check oil level, `top-up` hydraulic oil if necessary
191
- Manual gearbox: Change oil
(every 60,000 km (approx. 40,000 miles) vehicles with engine code AHT)
189
- Manual gearbox/final drive: Check oil level, top up with oil if necessary
187
- Brake system: Visual check for leaks and damage
197
- Brake pads (front and rear): Check thickness
198
- Underbody protection: Visual check for damage
203
- Exhaust system: Visual check for leaks, security and damage
- Track rod ends: Check play, security and boots
203
- Swivel joints: Visual check of swivel joint boots for leaks and damage
204
- Direct shift1): Check gear actuator sealing boot (on gearbox) for leaks and damage
- Tyre repair fluid1): Renew canister
(every 3 years)
205
- Tyres (including spare2)): Check condition and wear pattern
206
- Tyre tread depth (including spare2)): Check and enter ⇒
FL
FR
RR
RL
Spare
208
- Tyre pressures (including spare2)): Check, correct if necessary
209
- Engine oil: `Top-up` (Inspection service with oil change)
174
- Automatic gearbox: Check ATF level, top up if necessary
216
- Brake fluid change: Check if change is due (every 2 years) / additional work as a separate charge!
231
- Brake fluid level (dependent upon lining wear): Check
235
Page
- Carry out exhaust emission test3)/ additional work as a separate charge!
(3 years after initial registration and every 2 years thereafter)
265
- Headlight setting: Check, adjust if necessary
237
- Service sticker "Next service": Enter a cross at the position for the next service, oil change service or inspection service and enter date / odometer reading; enter a cross at the position for supplementary information (e.g. replacing toothed belt) and changing brake fluid along with date / odometer reading as necessary: Apply sticker to driver's door pillar (`B-pillar`) - service intervals =>page 13
34
- Carry out road test
