bradder Posted October 29, 2010 Report Share Posted October 29, 2010 ive just got my lupo back after the geabox went and it was driving fine for around 4hours and then all of a sudden it lost power and cut out and it wont fire back up now, has any one had this problem or no what it is iff you do please let me no thanks Quote Link to comment Share on other sites More sharing options...
treblet Posted October 29, 2010 Report Share Posted October 29, 2010 Have you checked the obvious things like spark plugs and leads, alternator etc?Will it even turn over? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted October 29, 2010 Report Share Posted October 29, 2010 Battery or alternator wires come off? Quote Link to comment Share on other sites More sharing options...
Mitchell Posted October 29, 2010 Report Share Posted October 29, 2010 gear box earth strap seeing as its been apart Quote Link to comment Share on other sites More sharing options...
Bradders123 Posted October 29, 2010 Report Share Posted October 29, 2010 I had this the other day and it turned out to be my battery, so check that. Quote Link to comment Share on other sites More sharing options...
bradder Posted October 30, 2010 Author Report Share Posted October 30, 2010 It turns over but it won't start it's like it's trying to Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted October 30, 2010 Report Share Posted October 30, 2010 gear box earth strap seeing as its been apartGood idea.Dont think its the fuel cut off ( I assume you other thread is about this problem?) Quote Link to comment Share on other sites More sharing options...
99hjhm Posted October 30, 2010 Report Share Posted October 30, 2010 Could be fuel pump, relay, fuse etc, If it's trying to start, doesn't sould ignition related. Quote Link to comment Share on other sites More sharing options...
LaydeeNina Posted November 1, 2010 Report Share Posted November 1, 2010 (edited) I had this problem with my lupo the engine tried to start but it just wouldnt ignite/turn over i changed the coil pack, ignition leads, spark plugs, fuel pump etc which cost me nearly £100 in total lol and still had the same problem =/, it turned out to be the ignition fuse a £2 job lol , check ur fuse box and find the symbol that looks like a spark plug, check that fuse, i bet its fried...in fact nearly all my problems have been due to blown fuses so id check all of them, you will be surprised at what you actually find. Edited November 1, 2010 by LaydeeNina Quote Link to comment Share on other sites More sharing options...
Rudaz Posted November 2, 2010 Report Share Posted November 2, 2010 (edited) I had this problem with my lupo the engine tried to start but it just wouldnt ignite/turn over i changed the coil pack, ignition leads, spark plugs, fuel pump etc which cost me nearly £100 in total lol and still had the same problem =/, it turned out to be the ignition fuse a £2 job lol , check ur fuse box and find the symbol that looks like a spark plug, check that fuse, i bet its fried...in fact nearly all my problems have been due to blown fuses so id check all of them, you will be surprised at what you actually find.i will +1 on this too Edited November 2, 2010 by Rudaz Quote Link to comment Share on other sites More sharing options...
