benjiboi Posted August 14, 2010 Report Share Posted August 14, 2010 hi i have a 1.4 16v lupo (75) 66000 miles and sometimes when i go to start it, it doesnt always start first time.... i have changed the plugs but that hasnt helped i just wonderd if this is common on them and/or what people think it is? thanks in advance. ben Quote Link to comment Share on other sites More sharing options...
Mike_M Posted August 14, 2010 Report Share Posted August 14, 2010 Coil pack and or leads cause engine misfire If it does not start then you could have a fault starter motor if it does not turn over Quote Link to comment Share on other sites More sharing options...
benjiboi Posted August 14, 2010 Author Report Share Posted August 14, 2010 Coil pack and or leads cause engine misfire If it does not start then you could have a fault starter motor if it does not turn overhi it does turn over it like just doesnt fire then when it does it sounds like it goin to cut out then kicks back in and is abit juddery for a while? Quote Link to comment Share on other sites More sharing options...
dmoffitt90 Posted August 15, 2010 Report Share Posted August 15, 2010 Temp coolant sensor could be the problem Quote Link to comment Share on other sites More sharing options...
.Phase Posted August 28, 2010 Report Share Posted August 28, 2010 I got a starting problem too! It is always first thing in morning rest of the day is fine... but it keeps trying to start and wont, yday I gave it a bit of revs and it started, and today turning the heater fans and stereo off made it start perfect! I will check oil level asap but im working all w/e Quote Link to comment Share on other sites More sharing options...
