one litre wonder ;) Posted December 25, 2004 Report Share Posted December 25, 2004 right i have a budget quite low and i like my sound quality , i have been looking at about 180/190 quid inc. wiring , so on the short list were ;audiobahn package-http://caraudiosecurity.com/catalog/produc...roducts_id+3025pioneer package -http://caraudiosecurity.com/catalog/produc...roducts_id+2649vibe package-http://caraudiosecurity.com/catalog/produc...roducts_id+2923so what do u recon , sorry tigz i couldnt find ur list of the good the bad and the ugly Quote Link to comment Share on other sites More sharing options...
Lee182Cup Posted December 25, 2004 Report Share Posted December 25, 2004 im getting the vibe cbr 10 active after da new yr Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 25, 2004 Author Report Share Posted December 25, 2004 i am strongly thinkin about it cause its 169.99 on its own or 179.99 with the wiring , so an extra tenner and your getting 20 quid off of ur wiring Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 25, 2004 Author Report Share Posted December 25, 2004 ma head unit has 3 rca's with a 4 or a 5v output , amd i am thinking of hte sub running 1 rca and then having a crossover for the doors and tweeters but who would u wiring it if u were going to run a set of 6*9s off of the head unit Quote Link to comment Share on other sites More sharing options...
nippyarosa Posted December 25, 2004 Report Share Posted December 25, 2004 i run my sub ofo the rca (only got one) and then the 6x9's are just connected to the rear speaker outputs. it doesn't make the most of the 6x9's but to be honest i reckon it sounds pretty sweet Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 25, 2004 Author Report Share Posted December 25, 2004 so is there like another cable i need to connect oor is it going to be a push fit connector ready to be used on ma head units wiring loom? Quote Link to comment Share on other sites More sharing options...
nippyarosa Posted December 25, 2004 Report Share Posted December 25, 2004 i took the little block connector thingy where the speaker cables connect to the headunit off and basically stuck the 6x9 cables into it and whacked it back in the headunit. is this what you were asking or have i completely misunderstood? Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 25, 2004 Author Report Share Posted December 25, 2004 i looked at the wiring diagram for ma head unit there and ut says that the third rca can be used as the output for the rear speakers that way all it would take to run them would be a phono to phono llead to hook them up Quote Link to comment Share on other sites More sharing options...
nippyarosa Posted December 25, 2004 Report Share Posted December 25, 2004 it only takes simple speaker cable to run them out of the normal speaker outputs, so you wouldn't be saving on any wire or anything. i suppose you're headunit may not have a normal rear speaker output? either way i think it'll be pretty much the same.sorry dude but i keep thinkin i'm not quite gettin your problem here, is there somethin i'm not understandin? feck it, i'm knackered and pretty much wasted so i'm sure everything'll make some more sense tomorrow Quote Link to comment Share on other sites More sharing options...
matt_arosa16v Posted December 26, 2004 Report Share Posted December 26, 2004 I know others will slag the Vibe off but i have it and am happy with it for my needs. Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 26, 2004 Report Share Posted December 26, 2004 for such a small car the vibe would be more than adequat... (spelling!?)dont use the speaker cables, use the RCA's, just get an RCA to RCA or Phono to Phono cable whatever you wanna call it, and whip it from head unit into bootthen all you need is an earth cable, from amp to an earth point, power cable from battery to amp, and a remote cable from the blue wire coming out the back of ur head unit. Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 26, 2004 Author Report Share Posted December 26, 2004 for such a small car the vibe would be more than adequat... (spelling!?)dont use the speaker cables, use the RCA's, just get an RCA to RCA or Phono to Phono cable whatever you wanna call it, and whip it from head unit into bootthen all you need is an earth cable, from amp to an earth point, power cable from battery to amp, and a remote cable from the blue wire coming out the back of ur head unit.yeah all the wiring i need should come in the wiring kit shouldnt it , that as well as for the 6*9's my rear speaker output IS an RCA to i will jst just a phono to phono wire and that will be that Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 26, 2004 Report Share Posted December 26, 2004 oh sorry i misread. DIdnt realise you wanted to run rear speakers. If you remove your stereo you should have a trailing lead coming out the back that connects to your VW wiring loom. On this trailing lead their will be a pair of Green wires (One green, one green with black stripe) and a pair of purple wires (one purple, one purple with black stripe. You will need to cut these, and join some new wires onto them, and run them down the side of the car to your parcel shelf.Remember - Black Stripe = Negativecan't quite remember which way round they are tho.I think its green - left, purple - right. Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 26, 2004 Author Report Share Posted December 26, 2004 oh sorry i misread. DIdnt realise you wanted to run rear speakers. If you remove your stereo you should have a trailing lead coming out the back that connects to your VW wiring loom. On this trailing lead their will be a pair of Green wires (One green, one green with black stripe) and a pair of purple wires (one purple, one purple with black stripe. You will need to cut these, and join some new wires onto them, and run them down the side of the car to your parcel shelf.Remember - Black Stripe = Negativecan't quite remember which way round they are tho.I think its green - left, purple - right.is that for running rear speakers , ( just ma head unit has an extra rca tht is for rear speakers / sub only so all i would need to do is connect it via rca ) or is that for wiring the sub cause what i was going to do is hook it up via rca then run the remote wire as well , run the 2 sets of rca's and the remote wire down one side then the power lines down the other Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 26, 2004 Author Report Share Posted December 26, 2004 oh ****** it , lee is there any way that ur mate can wire it up for me , i'll get all the parts and if he does out of work i'll pay him , just i cant be ass with the whole wirirng thing , just i know i will end up buggering it up some how Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 26, 2004 Report Share Posted December 26, 2004 RCA's go to amplifiers, Not speakers. If your running your 6x9's off an amplifier then the Rear/Sub RCA would go to the amp, then a speaker wire from the amp to the 6x9'sHowever if your running your 6x9's without an amp, you will need to do what i just described in my previous post. Shame ur in glasgow. Any closer and i'd have popped up n gave u a hand. Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 26, 2004 Author Report Share Posted December 26, 2004 yeah i just read that in ma wiring guid thing for the head unit , i am a tit ! lupogti_lee his mate works for halfords , i'll speak to lee and see if his mate if i pay him will wire it all up for me , ask me about engines and bodywork i know about , ask me about computers and home hifis i know about , ask me about ice and i will end up accidentally setting the car on fire Quote Link to comment Share on other sites More sharing options...
Lee182Cup Posted December 26, 2004 Report Share Posted December 26, 2004 il ask him but dunno how much he charges... Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 26, 2004 Report Share Posted December 26, 2004 i also work for halfords. but if i was to say thats where i learnt about car audio i'd be the worlds biggest lier. lol. Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 27, 2004 Author Report Share Posted December 27, 2004 how long would it take just to wire a sub and hide the wires??? Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 27, 2004 Author Report Share Posted December 27, 2004 just solved the problem of the rear speakers , mind i said that i was going to run 6*9s off of my head unit , i was wanting to run them off of the rca but u said that i would need to cut some wires well now i dont , just take the rca lead all the way to the speaker then put this bad boy in and it changes the rca to a speaker wire , jobs a good'in! http://www.incarexpress.co.uk/view_product...hp?partno=PX043 Quote Link to comment Share on other sites More sharing options...
nippyarosa Posted December 27, 2004 Report Share Posted December 27, 2004 dude just brave it, its not worth paying someone to do it, i dont know crap about electronics but its really not too hard. i can't believe your headunit doesn't have dedicated rear speaker outputs as well as the rca's Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 27, 2004 Report Share Posted December 27, 2004 style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" />+-->QUOTE(one litre wonder style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" />)just solved the problem of the rear speakers , mind i said that i was going to run 6*9s off of my head unit , i was wanting to run them off of the rca but u said that i would need to cut some wires well now i dont , just take the rca lead all the way to the speaker then put this bad boy in and it changes the rca to a speaker wire , jobs a good'in! http://www.incarexpress.co.uk/view_product.php?partno=PX043You can't wire a speaker to RCA outputs unless your putting an amp inbetween. I promise you that this is NOT what you do. Seriously now, If you arent running the 6x9's off the head unit, Use the Purple, Purple/Black, Green, Green/Black wires coming from your head unit. If tigs was here he'd back me up, but since he aint said much since `x-mas` eve i'll just have to wait for another resident ice expert to evaluate my comments. (please bare in mind i've worked with car audio since i was 11 years old)RCA's are a "LOW LEVEL" output designed to be fed to an amplifier, which increases the level to a "High level" output or a "Speaker output" If you wire a speaker to an RCA then you will get very little sound from them, and even that would be pushing it. I imagine you'd get no sound.Plus i dont think your Output IC is going to like seeing 4 ohms on the end of its pre outs. Quote Link to comment Share on other sites More sharing options...
tshirt2k Posted December 30, 2004 Report Share Posted December 30, 2004 DONT DO IT. RCA's are for amps only. Them connectors you showed are for headunits that don't have RCA outputs. They change the high level from the H/U to a suitable Low level that the amp can use. Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 30, 2004 Report Share Posted December 30, 2004 the only thing that will convert the signal from an RCA into a signal suitable to go to a speaker is an amplifier. Quote Link to comment Share on other sites More sharing options...
