Johnwin Posted March 10, 2010 Report Share Posted March 10, 2010 I'm putting sum vinyl on the roof of my loop..need to know how to remove or loosen the aerial base..grateful for any help..cheers Quote Link to comment Share on other sites More sharing options...
andyp Posted March 10, 2010 Report Share Posted March 10, 2010 need to undo your headling then undo the nut on the base underneath Quote Link to comment Share on other sites More sharing options...
Johnwin Posted March 10, 2010 Author Report Share Posted March 10, 2010 Sorry to be a pain in the a&£" but how does the headliner come loose?? Quote Link to comment Share on other sites More sharing options...
andyp Posted March 10, 2010 Report Share Posted March 10, 2010 undo the handles and take them out then theres two clips which you cant see which you have to sorta bend to pop out, if you have a feel behind lining you will find where they are Quote Link to comment Share on other sites More sharing options...
Johnwin Posted March 10, 2010 Author Report Share Posted March 10, 2010 (edited) Thanks alot for your help..now iv got a idea shud be alot easier Edited March 10, 2010 by Johnwin Quote Link to comment Share on other sites More sharing options...
andyp Posted March 10, 2010 Report Share Posted March 10, 2010 (edited) the clips are a pain as well, lots of swearing involved unless they pop out easy!! loloh and you unclip the aerial there as well as its located there Edited March 10, 2010 by andyp Quote Link to comment Share on other sites More sharing options...
Mike_M Posted March 11, 2010 Report Share Posted March 11, 2010 The aerial is also bolt to the roof by a 22mm nut, which will be seen once the headliner is lowered for access Quote Link to comment Share on other sites More sharing options...
