2001gti Posted November 26, 2009 Report Share Posted November 26, 2009 (edited) A friend of mine has a 318i and when she is going around corners she hears a knocking noise from the rear, alomost like somthing is sliding around in the boot. sounds to me like the diff. Anybody else care to have a guess?Tah Edited November 26, 2009 by 2001gti Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 26, 2009 Report Share Posted November 26, 2009 IIRC E36s have trouble with rear suspension components failing. Does it make the noise if she coasts round a corner? Quote Link to comment Share on other sites More sharing options...
electricpanda Posted November 26, 2009 Report Share Posted November 26, 2009 When mine did this it was the topmounts, not sure with a 318 though. Quote Link to comment Share on other sites More sharing options...
Philplop Posted November 26, 2009 Report Share Posted November 26, 2009 My mate's used to do this when he pulled away.Beemers are obviously cack! Quote Link to comment Share on other sites More sharing options...
1 Litre Screamer Posted November 26, 2009 Report Share Posted November 26, 2009 BMW's are well known for eating the rear trailing arm bushes. If you look under the car you will see the arm the comes from under the backseat to the lower wishbone assembly. Where this arm comes out of the chassis under the seat is a bush that always fails. Take it out and refit new powerflex bushes, dont use anything else as they will also wear very quickly. Quote Link to comment Share on other sites More sharing options...
