peteo Posted October 27, 2009 Report Share Posted October 27, 2009 As the title suggests im having a prob with the lupo revving when in neutral...Its wierd. Like when coming up to lights, whack it out of gear in to neutral and it revs from like 750rpm to up to about 1250... Does it about 3 or four times and then settles...Im not an engine guy myself... But i thought maybe the cluttch as it feels quite high anyway...Any help appreciatedPete Quote Link to comment Share on other sites More sharing options...
Mike_M Posted October 28, 2009 Report Share Posted October 28, 2009 Clutch does not effect the idle Quote Link to comment Share on other sites More sharing options...
northwick Posted October 28, 2009 Report Share Posted October 28, 2009 I'd guess an airflow sensor? The ECU is getting incorrect readings on the airflow through the engine and is over/undercompensating as a result. Quote Link to comment Share on other sites More sharing options...
peteo Posted October 28, 2009 Author Report Share Posted October 28, 2009 I'd guess an airflow sensor? The ECU is getting incorrect readings on the airflow through the engine and is over/undercompensating as a result.Would that be expensive to replace?... CheersPete Quote Link to comment Share on other sites More sharing options...
lupoluke Posted October 28, 2009 Report Share Posted October 28, 2009 As far as i know lupos dont use a MAF (mass air flow) sensor, they use MAP (manifold absolute pressure) sensor, is your engine light on, i would get it on Vag-Com to read the faults. If your engine light is not on just try giving the throttle body a clean. Quote Link to comment Share on other sites More sharing options...
peteo Posted October 28, 2009 Author Report Share Posted October 28, 2009 As far as i know lupos dont use a MAF (mass air flow) sensor, they use MAP (manifold absolute pressure) sensor, is your engine light on, i would get it on Vag-Com to read the faults. If your engine light is not on just try giving the throttle body a clean.No there arent any warning lights on or anything like that. It just revs. Forgot to mention its pretty abrupt and shakes the car when it does it!..Jus a point, when i was looking through the forums last night noticed that your (luke) from 'north west'.. U from anywhere near ursmton?.. Sure ive seen a car like yours around there...Pete Quote Link to comment Share on other sites More sharing options...
lupoluke Posted October 28, 2009 Report Share Posted October 28, 2009 Yes mate im from partington, got a load of family in flixton and urmston, and i used to commute daily through there to get to stretford. What colours your loop pall is there any mods. Quote Link to comment Share on other sites More sharing options...
northwick Posted October 28, 2009 Report Share Posted October 28, 2009 As far as i know lupos dont use a MAF (mass air flow) sensor, they use MAP (manifold absolute pressure) sensor.Good point. Does sound like an air issue though if it does it at idle but not whilst running. Quote Link to comment Share on other sites More sharing options...
lupoluke Posted October 28, 2009 Report Share Posted October 28, 2009 The first thing i would do is disconnect the battery for half an hour then connect it back up and start the car and let it run with out touching anything till the fan kicks in. And if didnt know the past of the car i would give it a full service and clean the throttle body, and check for air leaks, then if that fails i would change the map sensor. Quote Link to comment Share on other sites More sharing options...
peteo Posted October 30, 2009 Author Report Share Posted October 30, 2009 Yes mate im from partington, got a load of family in flixton and urmston, and i used to commute daily through there to get to stretford. What colours your loop pall is there any mods.w-reg red... completely standard... Had it since end of July and havent done anything yet!.. Not sure what i wanna do. Defo wanna paint it. Think i'd go matte orange or pearl white... But atm not sure of anything else. Bought it as a commuter really but you jus cant help yourself wanting to mod it, ey...Next time i see you i'll give you a toot mate!Pete Quote Link to comment Share on other sites More sharing options...
lupoluke Posted October 30, 2009 Report Share Posted October 30, 2009 Yes mate, if you see us pull up an i will have a gander an tell you what i think the problem is. Quote Link to comment Share on other sites More sharing options...
peteo Posted October 31, 2009 Author Report Share Posted October 31, 2009 Yes mate, if you see us pull up an i will have a gander an tell you what i think the problem is.nice one mate Quote Link to comment Share on other sites More sharing options...
