little rich Posted May 10, 2009 Report Share Posted May 10, 2009 Alright all, this isnt for be but for Carly off of here with a black 1.4she has sent her wheels off to be banded, there 14" and et 38,she wants 8's all round but were just wondering if they would rub? she will be getting the arches rolled if need be,im pretty sure there rears will be fine but not too sure about the fronts?Thanks in advance Rich Quote Link to comment Share on other sites More sharing options...
pro3mark Posted May 10, 2009 Report Share Posted May 10, 2009 What width were they standard, that way i'll be able to work out the new offset.And also the tire size?Cheers mateMark Quote Link to comment Share on other sites More sharing options...
little rich Posted May 10, 2009 Author Report Share Posted May 10, 2009 The people banding them said that the ET will stay the same due to the place that they are cutting them,? any way they are 6jtyre's will probably be what im running at the back on my 8s (cant think off the top of my head what they are!)Thanks Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted May 10, 2009 Report Share Posted May 10, 2009 The people banding them said that the ET will stay the same due to the place that they are cutting them,? any way they are 6jtyre's will probably be what im running at the back on my 8s (cant think off the top of my head what they are!)Thanksunless theyre banding them removing the centre and repositioning the centre then the et will change im s Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted May 11, 2009 Report Share Posted May 11, 2009 Yep i thought if you band in front of the centre you decreased the ET, so they must be putting a 1 inch band either side of the centre to keep the ET the same. Quote Link to comment Share on other sites More sharing options...
Shteee Posted May 11, 2009 Report Share Posted May 11, 2009 As above mate, ET will change unless they band the same size strips to both the front and back of the wheel Quote Link to comment Share on other sites More sharing options...
bobbo Posted May 11, 2009 Report Share Posted May 11, 2009 What steels are they, i managed to fit mk2 driver steels banded to 8" on mine no problems, Dont know what the ET of those is though Quote Link to comment Share on other sites More sharing options...
Philplop Posted May 11, 2009 Report Share Posted May 11, 2009 If you band them to 8J the new offset will be et13. Quote Link to comment Share on other sites More sharing options...
little rich Posted May 11, 2009 Author Report Share Posted May 11, 2009 Ok Thanks for the replys so far,The place doing it said that the et wont change, as they cut it tight to the back/front of the wheel? dont quote me on that!Any way if the et does change to et13 would 8s all round be ok? more worried about the front,Thanks Quote Link to comment Share on other sites More sharing options...
Jowey Posted May 11, 2009 Report Share Posted May 11, 2009 are they definitely getting banded and not widened ? Quote Link to comment Share on other sites More sharing options...
Jowey Posted May 11, 2009 Report Share Posted May 11, 2009 13X8 ET1 is fine up front. Quote Link to comment Share on other sites More sharing options...
little rich Posted May 11, 2009 Author Report Share Posted May 11, 2009 Cheers,and jowey they are being cut and a band put it, Rich, Quote Link to comment Share on other sites More sharing options...
Jowey Posted May 11, 2009 Report Share Posted May 11, 2009 (edited) 8JXR13 ET1 175/50oh and its your car Rich Edited May 11, 2009 by Jowey Quote Link to comment Share on other sites More sharing options...
little rich Posted May 11, 2009 Author Report Share Posted May 11, 2009 Indeed it is jowey but there 13's 8s have been ordered now! ta very much, Quote Link to comment Share on other sites More sharing options...
Jowey Posted May 11, 2009 Report Share Posted May 11, 2009 oh i didnt read the 14's bit Quote Link to comment Share on other sites More sharing options...
matt~black Posted May 11, 2009 Report Share Posted May 11, 2009 are they definitely getting banded and not widened ?can you widen them without banding them??? Quote Link to comment Share on other sites More sharing options...
Jowey Posted May 11, 2009 Report Share Posted May 11, 2009 can you widen them without banding them???8 wheels into 4swap the outer lip for the inner lip Quote Link to comment Share on other sites More sharing options...
matt~black Posted May 12, 2009 Report Share Posted May 12, 2009 8 wheels into 4swap the outer lip for the inner lipI don't understand how u mean do you have pictures nothing on howstuffworks.com Quote Link to comment Share on other sites More sharing options...
biggaz Posted May 12, 2009 Report Share Posted May 12, 2009 Is that not still cutting them up and welding?et13 wont be too bad, will scrub if you go low enough up front, rear will be ok as the dont go THAT low anyway, when you have people in the back though there will be rubbing i would have thought, most of the time it should be ok.probably fitting 195/45's? yeh? Quote Link to comment Share on other sites More sharing options...
Philplop Posted May 12, 2009 Report Share Posted May 12, 2009 As said, the only way the et won't change is if there's a band put in front of the face and behind it, ie, two bands.The et will change, maybe they are referring to the inside clearance, as the inside lip of the wheel will be in the same position as before.Who's doing it? Sounds like they don't know what they're talking about? Quote Link to comment Share on other sites More sharing options...
little rich Posted May 12, 2009 Author Report Share Posted May 12, 2009 ^ haha! i was always led to believe that the et changed too,We dropped them off at a house in Heathrow, they do all the wheels for stock racing cars etc, think he does a few on ED38 too,Thanks, Quote Link to comment Share on other sites More sharing options...
Jowey Posted May 13, 2009 Report Share Posted May 13, 2009 Is that not still cutting them up and welding?I don't understand how u mean do you have pictures nothing on howstuffworks.comYup you're right it will still involve cutting them up and welding, but its only one weld and no rolled steel band is added.Hence why the are not 'Banded' but widened.http://www.pngclub.com/forum/showthread.php?t=94927 Quote Link to comment Share on other sites More sharing options...
matt~black Posted May 13, 2009 Report Share Posted May 13, 2009 ah got ya that takes 8 wheels to make 4 wide ones though rich how much is it costing if ya don't mind me asking? Quote Link to comment Share on other sites More sharing options...
little rich Posted May 15, 2009 Author Report Share Posted May 15, 2009 200 notes i believe, Quote Link to comment Share on other sites More sharing options...
MattTDI Posted May 15, 2009 Report Share Posted May 15, 2009 now then rich, do they come with a no leak guarantee? thats a good price! Quote Link to comment Share on other sites More sharing options...
