NivGTI Posted April 17, 2009 Report Share Posted April 17, 2009 Hello everyone.....im new to this forum so sorry if i have posted this in the wrong section..Iv got a Polo GTI 6n2 and as you know the gearbox's are absolute pants!.. I was looking the lupo GTI 6 spead gearboxs and was wondering if they would be a stright fit or would they require ablot of modifying?any help would be much appricated Thank You Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted April 17, 2009 Report Share Posted April 17, 2009 i think the bellhousing is different on the 6speed, and Lupo's use a hydralic clutch, though that may not be a problemwhere's Tigz when you need him!?Oh and welcome to ClubLupo! Quote Link to comment Share on other sites More sharing options...
NivGTI Posted April 20, 2009 Author Report Share Posted April 20, 2009 i think the bellhousing is different on the 6speed, and Lupo's use a hydralic clutch, though that may not be a problemwhere's Tigz when you need him!?Oh and welcome to ClubLupo!Thanks mate......I was hoping for it to been a stright swap...dam never work out that way ...lol Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted April 20, 2009 Report Share Posted April 20, 2009 Its completely different, although it could be done if you really wanted a 6 Speed.The engine bell housing is different, so you would need a Lupo GTI Sump.The exhaust is also different on the GTI so you would need to adjust your exhaust to clear the sump.The gear linkage is different.The clutch on the Lupo GTI is hydrolic, so you'd need to change the pedal box, Slave and master cylinder.The Gearbox speedo sensor is different, so you'd either need to replace this, or replace the plug on your loom.The Lupo GTI box also fails, its not a Polo GTI thing, its accross the VW range for as far back as the mk1 Golf GTI!So long as the Polo GTI box is rebuilt using the upgraded VW repair kit it should be good for another 40k miles.I'd imagine it'd be someone elses problem by then. Quote Link to comment Share on other sites More sharing options...
NivGTI Posted April 21, 2009 Author Report Share Posted April 21, 2009 Its completely different, although it could be done if you really wanted a 6 Speed.The engine bell housing is different, so you would need a Lupo GTI Sump.The exhaust is also different on the GTI so you would need to adjust your exhaust to clear the sump.The gear linkage is different.The clutch on the Lupo GTI is hydrolic, so you'd need to change the pedal box, Slave and master cylinder.The Gearbox speedo sensor is different, so you'd either need to replace this, or replace the plug on your loom.The Lupo GTI box also fails, its not a Polo GTI thing, its accross the VW range for as far back as the mk1 Golf GTI!So long as the Polo GTI box is rebuilt using the upgraded VW repair kit it should be good for another 40k miles.I'd imagine it'd be someone elses problem by then.Thanks alot Tigs....that sound like too much work and not worth the money...i think ill scrap that idea lol Quote Link to comment Share on other sites More sharing options...
Petar001 Posted May 12, 2009 Report Share Posted May 12, 2009 TIGZ do you have any part number for upgraded VW repair kit ??what do i need to buy to rebuilt my polo gti box ? thanks Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted May 12, 2009 Report Share Posted May 12, 2009 085 311 123 D x3 (timkin XC06536CD-JXC06536DC) 2xLayshaft, 1xMain Shaft311 405 625 F x1 (timkin XC10240CJ-XC10240DH) Mainshaft411 501 283 G x2 (no timkin numbers taken, sorry!) Diff Bearings085 311 431 C x1 (Crappy plastic bearing) 5th Gear Idler Bearing085 311 113 x1 Seal084 409 189 C x1 Diff Seal 084 409 189 B x1 Diff Seal 085 301 215 A x1 End Plate Gasket085 311 582 x1 Crappy Clip Thats Bound to Break, holds in selectors. If you want to 'Upgrade' the only thing which can be 'upgraded' is the plastic 5th gear bearing with a metal item but TBH so long as the gear oil is changed regually (I change mine everytime I change the engine oil) it should be fine. Quote Link to comment Share on other sites More sharing options...
thezootfather Posted December 12, 2024 Report Share Posted December 12, 2024 On 5/12/2009 at 11:16 AM, Tigz™ said: 085 311 123 D x3 (timkin XC06536CD-JXC06536DC) 2xLayshaft, 1xMain Shaft 311 405 625 F x1 (timkin XC10240CJ-XC10240DH) Mainshaft 411 501 283 G x2 (no timkin numbers taken, sorry!) Diff Bearings 085 311 431 C x1 (Crappy plastic bearing) 5th Gear Idler Bearing 085 311 113 x1 Seal 084 409 189 C x1 Diff Seal 084 409 189 B x1 Diff Seal 085 301 215 A x1 End Plate Gasket 085 311 582 x1 Crappy Clip Thats Bound to Break, holds in selectors. If you want to 'Upgrade' the only thing which can be 'upgraded' is the plastic 5th gear bearing with a metal item but TBH so long as the gear oil is changed regually (I change mine everytime I change the engine oil) it should be fine. This is great info to have. I've just had my GTi box start to fail in 2024 - wish me luck on sourcing these! Quote Link to comment Share on other sites More sharing options...
