Coilovers and uprated ARB's on a lupo
Altern8
  • Replies 62
  • Created
  • Last Reply
Top Posters In This Topic
i believe air bag suspension comes in at around 900 - 1000 quid. i dono how those would fit/if? i got a better quote for just the juice systems from another guy. novice 2 pump are 820 for the full kit except the custom bits. Pro Competition 1100 (with joystick for bouncing. can really make ur car dance) and then the final killer one
LA series 4 pump Fat steel system.
Pre wired 10 switch box, accurate solenoids, Italian dumps, 1" ports, #8 hoses, competition cylinders, Parker competiton check valves and slow downs.
You can do some serious hopping with this stuff... obviously youd wanna plate up your egine and bits n bobs
looks like the front standard arbs are 18mm so if the eibach one is thicker smile.gif style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> but i also found this so mabey eibach did make a mistake and made them 21 mm sad.gif style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" />
Manufacturer : Eibach
Category : Eibach `Anti-Roll` Bar Kits
`Sub-category` : Eibach A/Roll - VW
Application : Lupo (6X1/6E1) 1.0, 1.4, 1.4 16V, 1.6 GTi, 1.4 TDI, 1.7 SDI ; 10.98 -
Details : Non adjustable. Bar diameter = 21 mm
I think that you shouldnt need an anti roll bar on the rear with the type of rear susspention.
Does that sound about right techies or do I understand it wrong?
in PVW theres a article on chassis upgrades for the lupo and they say to only put ARB on the front of the car.
