mdubgti Posted October 5, 2004 Report Share Posted October 5, 2004 well heres the prob. because lupos have McPH front struts they will need custom bits underneath they will need to be one off made, these juice systems are designed to fit striaght to mainly yank cars. Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted October 5, 2004 Report Share Posted October 5, 2004 So it would be possable to do a DIY job then?(Im not thinking of doing this by the way, even if its a quick job I havn't got £1300!) Quote Link to comment Share on other sites More sharing options...
mdubgti Posted October 5, 2004 Report Share Posted October 5, 2004 i believe air bag suspension comes in at around 900 - 1000 quid. i dono how those would fit/if? i got a better quote for just the juice systems from another guy. novice 2 pump are 820 for the full kit except the custom bits. Pro Competition 1100 (with joystick for bouncing. can really make ur car dance) and then the final killer one LA series 4 pump Fat steel system.Pre wired 10 switch box, accurate solenoids, Italian dumps, 1" ports, #8 hoses, competition cylinders, Parker competiton check valves and slow downs.You can do some serious hopping with this stuff... obviously youd wanna plate up your egine and bits n bobs Quote Link to comment Share on other sites More sharing options...
mdubgti Posted October 5, 2004 Report Share Posted October 5, 2004 it would be poss... yeah im pretty sure. spisi! here we come buddy style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
DanGTI Posted October 6, 2004 Report Share Posted October 6, 2004 no snoop not saying there r rules, just doesnt seem right it just makes sense to me that if a cars low, thats just how it is....not just low when its parked or cruising round Quote Link to comment Share on other sites More sharing options...
Altern8 Posted October 8, 2004 Author Report Share Posted October 8, 2004 looks like the front standard arbs are 18mm so if the eibach one is thicker style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> but i also found this so mabey eibach did make a mistake and made them 21 mm style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" />Manufacturer : EibachCategory : Eibach `Anti-Roll` Bar Kits`Sub-category` : Eibach A/Roll - VWApplication : Lupo (6X1/6E1) 1.0, 1.4, 1.4 16V, 1.6 GTi, 1.4 TDI, 1.7 SDI ; 10.98 - Details : Non adjustable. Bar diameter = 21 mm Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted October 8, 2004 Report Share Posted October 8, 2004 I think a non sport/GTi is 18mm Sport/GTi 23mmIm pretty sure thats right.. Quote Link to comment Share on other sites More sharing options...
Altern8 Posted October 9, 2004 Author Report Share Posted October 9, 2004 does the gti have a rear ARB or is it the same as the rest of the range ? Quote Link to comment Share on other sites More sharing options...
Snoopy Posted October 9, 2004 Report Share Posted October 9, 2004 Same as the rest as I understand it. Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted October 9, 2004 Report Share Posted October 9, 2004 I think that you shouldnt need an anti roll bar on the rear with the type of rear susspention.Does that sound about right techies or do I understand it wrong? Quote Link to comment Share on other sites More sharing options...
Snoopy Posted October 9, 2004 Report Share Posted October 9, 2004 It'll probably increase understeer a bit. Quote Link to comment Share on other sites More sharing options...
Dogwood Posted October 11, 2004 Report Share Posted October 11, 2004 GTI has a rear bar welded into the `V-section` of the beam, same as Golf GTI's. Without measuring, its about 25mm I think. Quote Link to comment Share on other sites More sharing options...
mdubgti Posted October 15, 2004 Report Share Posted October 15, 2004 I think that you shouldnt need an anti roll bar on the rear with the type of rear susspention.Does that sound about right techies or do I understand it wrong?in PVW theres a article on chassis upgrades for the lupo and they say to only put ARB on the front of the car. Quote Link to comment Share on other sites More sharing options...
