Glupo Posted November 8, 2008 Report Share Posted November 8, 2008 Hi, as title I am going to look at a 1.4S tomorrow. It has low mileage and fsh. Being reasonably mech minded, what should I check over?Thank you pleaseP.S. Just watched an encouraging youtube vid of the 'W12' on full pelt and a few 1.4 clips to get me going... Quote Link to comment Share on other sites More sharing options...
Mitchell Posted November 9, 2008 Report Share Posted November 9, 2008 burning oil ,poor gear change , break pedal lower than clutch, pedal box, rear wiper motors can fail, and rust blisters along roof guttering. hope you find a good one. Quote Link to comment Share on other sites More sharing options...
Glupo Posted November 9, 2008 Author Report Share Posted November 9, 2008 Went to look at a nice looking one but wasn't all good to go so walked away. How much would you pay for a clean example? Quote Link to comment Share on other sites More sharing options...
Liam_r Posted November 10, 2008 Report Share Posted November 10, 2008 yeah anymore info on what to look for? fair enough you walked away mate, takes guts! Quote Link to comment Share on other sites More sharing options...
steve200 Posted November 11, 2008 Report Share Posted November 11, 2008 They are reliable enough and if its been looked after rust shouldnt be a problem. Only issue I had, was the car would not idle properly, but cleaning the throttle body cleared that problem.I haved owned it just over 2 years and its only needed a back box and tyres. Quote Link to comment Share on other sites More sharing options...
Mitchell Posted November 12, 2008 Report Share Posted November 12, 2008 They are reliable enough and if its been looked after rust shouldnt be a problem. Only issue I had, was the car would not idle properly, but cleaning the throttle body cleared that problem.I haved owned it just over 2 years and its only needed a back box and tyres. rust in the roof guttering is from inside out so has nothing to do with being looked after i'm afraid, just poor build . Quote Link to comment Share on other sites More sharing options...
steve200 Posted November 12, 2008 Report Share Posted November 12, 2008 rust in the roof guttering is from inside out so has nothing to do with being looked after i'm afraid, just poor build .Can the roof lining be removed to see this, or is the guttering not reachable (sealed panel). Im Interested in this, if its common problem I would like to try and prevent it. Thanks Quote Link to comment Share on other sites More sharing options...
Cliveski Posted November 16, 2008 Report Share Posted November 16, 2008 Cambelt change can be expensive and needs doing every 40k/4 years whichever comes soonest.My rear drum brakes used to 'glaze' on my 1.4's and be noisy under braking - needed deglazing/cleaning.I had several flexi-pipe's go on the front exhaust section which needed replacing (about £180 if I remember correctly as the CAT is attached to the front section). Listen out for a rattle like a metal pea in a tin when the car is coasting and slowing down.Key codes can be useful. Electric window motors sometimes go. Quote Link to comment Share on other sites More sharing options...
dannymcflylol Posted November 17, 2008 Report Share Posted November 17, 2008 Shame-less plug but I have one for sale with none of the mentioned problems haha. Quote Link to comment Share on other sites More sharing options...
yotsuba Posted November 17, 2008 Report Share Posted November 17, 2008 Hi when i purchased my loopo..the door was off the hinges so it felt like the door was dropping....but that can be fixed by tightening the hinges....and yes i needed to service mine because the previous owner didnt and missed the 30k one i think...cant quite remember....so yeh check the door! but thats a common problem i heard Quote Link to comment Share on other sites More sharing options...
charlie-says Posted November 26, 2008 Report Share Posted November 26, 2008 I got my roof gutterings repaired for free last month under corrosion guarantee at VW. Quote Link to comment Share on other sites More sharing options...
