Alex_225 Posted September 3, 2008 Report Share Posted September 3, 2008 Right guys I know that to get my Pioneer headunit working properly I need to swap the red and yellow leads round.I believe its the leads on the adapter from the headunit rather than the wires attached to the car. Is that correct?Also are they eash to remove??? Just pull out on a kinda crimp connection of some kind? Cheers in advance. Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted September 3, 2008 Report Share Posted September 3, 2008 Yes swap them on your adaptor rather than your loom. The red and yellow connectors should just be butt connections inside plastic sleaves?If so just pull them apart. Quote Link to comment Share on other sites More sharing options...
Alex_225 Posted September 3, 2008 Author Report Share Posted September 3, 2008 I'm assuming they're easy to swap back???The headunit has been in two Renaults and never needed it done so just a bit cautious. Quote Link to comment Share on other sites More sharing options...
Paul R Posted September 10, 2008 Report Share Posted September 10, 2008 I'm assuming they're easy to swap back???Yup, as above there inside the plasctic sleave/cover thing and are just as easy to change as to put them back. Why you would want to change them back tho? Quote Link to comment Share on other sites More sharing options...
