Poobah Posted August 3, 2004 Author Report Share Posted August 3, 2004 Evo and the stealers must have it wrong...seems strange though!C Quote Link to comment Share on other sites More sharing options...
mickyp Posted August 3, 2004 Report Share Posted August 3, 2004 the lupo does have some sort of traction control.becasue some times when i spin the front wheels slightly u can here it come in. Quote Link to comment Share on other sites More sharing options...
gargoil Posted August 3, 2004 Report Share Posted August 3, 2004 QUOTE(mickyp)the lupo does have some sort of traction control.becasue some times when i spin the front wheels slightly u can here it come in. I thought so too but there is no mention of it on the uyk vw site for the lupo gti either as standard or as an option!confused now! :? Quote Link to comment Share on other sites More sharing options...
bossjohnc Posted August 3, 2004 Report Share Posted August 3, 2004 That's EDL - it won't let the front wheels spin at different speeds below 50mph.If you floor it however, your wheels will be spinning at the same rate. Quote Link to comment Share on other sites More sharing options...
mickyp Posted August 3, 2004 Report Share Posted August 3, 2004 i can't explain the sound it makes when it comes on but u will probably of heard it.its when your grip on the wheel just slips that little bit u can hear it. Quote Link to comment Share on other sites More sharing options...
bossjohnc Posted August 3, 2004 Report Share Posted August 3, 2004 Yup, that'll be it... sounds a bit like the ABS kicking in? Quote Link to comment Share on other sites More sharing options...
Crusoe Posted August 3, 2004 Report Share Posted August 3, 2004 it brakes the spinning wheel EDL standing for electronic differential lock. Will still let both wheels spin as long as they are both at the same speed. Works well in the snow. Quote Link to comment Share on other sites More sharing options...
Ardent Posted August 3, 2004 Report Share Posted August 3, 2004 left foot braking = loss of power in mine, quite `un-nerving`jayson my 2p Quote Link to comment Share on other sites More sharing options...
Snoopy Posted August 3, 2004 Report Share Posted August 3, 2004 Yup, very spooky.Note that if you're just parked in neutral, applying the brake won't stop you from revving the engine. But if you apply the brake for more than half a second while the accelerator is pressed, you'll suddenly find that you've lost (approx) 80% power. I was able to maintain 40mph when I tried it on the way back, but not accelerate any faster.Note that if you do this a lot, you will raise a fault code. :wink: Quote Link to comment Share on other sites More sharing options...
Snoopy Posted August 3, 2004 Report Share Posted August 3, 2004 QUOTE(Poobah)Also noticed that the ESP system is less pronounced on 5 speed cars.Wonder if this could be simply due to the gearing - it'll be a bit harder to spin the wheels in first/second, as they're higher ratios on the 5 speed. Quote Link to comment Share on other sites More sharing options...
