DubDub Posted June 24, 2004 Report Share Posted June 24, 2004 Just happened today...Got in the car and noticed that the boot lid warning light on th dash was on, so I opened and closed the boot but it stayed lit.Now heres the strange part. When the boot is closed the light is on, but it aint as bright as when the boot is actually open.Heres with the Boot open: border="0" class="linked-image" /> border="0" class="linked-image" />and when the boot is closed it fades a bit but still stays on?Any suggestions techies? Quote Link to comment Share on other sites More sharing options...
bossjohnc Posted June 24, 2004 Report Share Posted June 24, 2004 Uh oh... does your rear screen wash work properly?? Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted June 24, 2004 Report Share Posted June 24, 2004 I pulled my wire out in the end as I got sick of it comin on.Had to `re-attach` it in the end as I realised my Alarm Id just spend £200 on didnt sound if my boot got broken into! lolSame responce as John, has your rear wash started leaking? Quote Link to comment Share on other sites More sharing options...
EssexLoop Posted June 24, 2004 Report Share Posted June 24, 2004 i had the same problem once with my boot sensor, took it back to vw and they replaced it Quote Link to comment Share on other sites More sharing options...
DubDub Posted June 24, 2004 Author Report Share Posted June 24, 2004 On the way out after posting this thread, it came on again. But by the time I got to the Pub it was ok again?I'll give the rear washer a look tomorrow.Ta Guys Quote Link to comment Share on other sites More sharing options...
MacGargoil Posted June 25, 2004 Report Share Posted June 25, 2004 yup water pishing into the sensor, happened to me in the middle of the night and the alarm kept going off every 10mins all night long! Quote Link to comment Share on other sites More sharing options...
DubDub Posted June 25, 2004 Author Report Share Posted June 25, 2004 Where is the sensor? Is it a case of stripping the Boot hatch? Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted June 25, 2004 Report Share Posted June 25, 2004 Take off your plastic cover from the boot door and you'll see the black wire leading to behind the boot door handle. Quote Link to comment Share on other sites More sharing options...
MacGargoil Posted June 25, 2004 Report Share Posted June 25, 2004 take off the trim on the inside of the boot lid. put the window spray connector back on to the nozzle nipple. wipe away the moisture and then use a hairdryer on the entire area for a few mins. this worked for me! Quote Link to comment Share on other sites More sharing options...
philbee Posted June 25, 2004 Report Share Posted June 25, 2004 Its a well known problem at VW. Either the rear wash wipe pipe or the wiper module is broken. The sensor is on the door latch directly below the wiper. Had exactly the same problem on my 02 GTI.Take it back to VW and get it fixed under warranty. Quote Link to comment Share on other sites More sharing options...
gargoil Posted June 25, 2004 Report Share Posted June 25, 2004 I superglued the pipe on, which probably not the best solution but it stops it! I also got a small plastic bag and covered up the electrics just in case it happens again! Quote Link to comment Share on other sites More sharing options...
DubDub Posted June 25, 2004 Author Report Share Posted June 25, 2004 cheers for the responses guys, will give it a go. Quote Link to comment Share on other sites More sharing options...
