Which oil should i buy ?
Seen some Mobil 1 in Halfords, not sure which viscosity maybe 5w30. Is this the best oil i could buy for my GTI ?
My manual says the oil capacity is 3.2L, i know it's a dumb thing to ask but am i reading this right ? 3.2L is feck all LOL
Edited by L119 UPO
  • 3 months later...
In my Arosa handbook it has a little chart that shows you the right grades to use depending on the conditions - so it has one for use as a general oil, then shows you what to change to if its very very very cold....
I tend to use 10W40, but I've got a different engine to you
I use Shell Helix Ultra 5W-40. Personally I think its brilliant stuff.
Mobil 1 won't be that bad either i'm sure.
0W-40 and 5W-40 are the same viscosity, they are both 5 weight oils that wont thin more than a 40 weight. It's just that 0W-40 will be pourable at a much lower temp.
