spaniel Posted May 24, 2006 Report Share Posted May 24, 2006 right a friend of mine. has a tdi lupo 1.4 75 bhp. he has a larger intercooler that he wants to fit to it, and was planning on a chip. he was wondering if anyone has turned up the boost on the turbo and if so how? any info on this would be great and where to get a chip for it would be good too.thanks style="vertical-align:middle" emoid=":D" border="0" alt="biggrin.gif" /> dan Quote Link to comment Share on other sites More sharing options...
Teflon Posted May 24, 2006 Report Share Posted May 24, 2006 it is possible to up the boost but the boost is controlled electronicly by a solenoid valve which is mounted on the bulkhead.1. you could place a restrictor in one of the boost control hoses (not the one that goes to the air filter)2. you could adjust the length of the wastegate control level on the turbocharger by undoing the nut then tuning the rod in (make it shorter)but i couldn't reccomend either of these!!! Quote Link to comment Share on other sites More sharing options...
Max69vk Posted May 24, 2006 Report Share Posted May 24, 2006 (edited) I got my tdi done with a Superchip & the difference it makes is awesome! I wouldnt bother with the larger intercooler, had a look into it & it wont make any real difference + it may actually give you more turbo lag which isn't good.Oh & the boost is controlled by the ECU which in turn controls the N75, EGR, actuator etc etc. Whilst the restrictor in the N75 line can give a faster 'spike' in boost pick up, if you've already got the car chipped (or even in some standard cars) it can lead to overboosting & even shutting down into 'limp mode' which isn't good. Edited May 24, 2006 by Max69vk Quote Link to comment Share on other sites More sharing options...
sleeky tdi Posted May 24, 2006 Report Share Posted May 24, 2006 Aye as above, just get it remapped by a well known tuner, Jabbasport, superchips, customcode, etc.. style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" />Lee. Quote Link to comment Share on other sites More sharing options...
Red Lup Gti Posted May 24, 2006 Report Share Posted May 24, 2006 it is possible to up the boost but the boost is controlled electronicly by a solenoid valve which is mounted on the bulkhead.1. you could place a restrictor in one of the boost control hoses (not the one that goes to the air filter)2. you could adjust the length of the wastegate control level on the turbocharger by undoing the nut then tuning the rod in (make it shorter)but i couldn't reccomend either of these!!!Wouldnt makeing the rod shorter open the waste gate? surly you would want to lengthen the rod. Quote Link to comment Share on other sites More sharing options...
Teflon Posted May 24, 2006 Report Share Posted May 24, 2006 Wouldnt makeing the rod shorter open the waste gate? surly you would want to lengthen the rod.yes, you are absosultely right! sorrymy brain isn't switched on today. Quote Link to comment Share on other sites More sharing options...
nfbr Posted May 24, 2006 Report Share Posted May 24, 2006 it is possible to up the boost but the boost is controlled electronicly by a solenoid valve which is mounted on the bulkhead.1. you could place a restrictor in one of the boost control hoses (not the one that goes to the air filter)2. you could adjust the length of the wastegate control level on the turbocharger by undoing the nut then tuning the rod in (make it shorter)but i couldn't reccomend either of these!!!WRONG...Their is no true wastegate on the lupo 1.4 tdi's turbo charger as it is VNT type turbo which is electronically controlledas for a "restrictor" this wont work, as it simply sends the ECU into error and drops you into "boost leak" mode, which means basically you'll end up running a 1.4 3-cyl SDI...The boost pressure is only changeable by remapping the car completely.Oh & the boost is controlled by the ECU which in turn controls the N75, EGR, actuator etc etc. Whilst the restrictor in the N75 line can give a faster 'spike' in boost pick up, if you've already got the car chipped (or even in some standard cars) it can lead to overboosting & even shutting down into 'limp mode' which isn't good.What he said. Quote Link to comment Share on other sites More sharing options...
Teflon Posted May 25, 2006 Report Share Posted May 25, 2006 i owned a tdi lupo about 7 years ago and it definately had a convetional internal wastegate on the turbocharger. and it wasn't a vnt unit. i know that the audi a2 tdi had a vnt unit tho Quote Link to comment Share on other sites More sharing options...
Max69vk Posted May 25, 2006 Report Share Posted May 25, 2006 (edited) The Audi A2, VW Lupo & Arosa TDI all use the same lump & electronics. Part of the reason for the success of the modern turbo diesel has been the use of VNT turbos, because of the way it operates its like having a tiny turbo for faster spooling/pick up & then its 'morphs'* to act like a larger unit for higher end grunt. *= Couldn't think of a more suitable word to use! style="vertical-align:middle" emoid=":lol:" border="0" alt="laugh.gif" /> Edited May 25, 2006 by Max69vk Quote Link to comment Share on other sites More sharing options...
nfbr Posted May 28, 2006 Report Share Posted May 28, 2006 border="0" class="linked-image" /> border="0" alt="" /> Quote Link to comment Share on other sites More sharing options...
Max69vk Posted May 28, 2006 Report Share Posted May 28, 2006 In the words of Tommy Cooper...... Just like that! style="vertical-align:middle" emoid=":lol:" border="0" alt="laugh.gif" /> Quote Link to comment Share on other sites More sharing options...
Tigzâ„¢ Posted May 28, 2006 Report Share Posted May 28, 2006 Thats very clever. Quote Link to comment Share on other sites More sharing options...
nfbr Posted May 31, 2006 Report Share Posted May 31, 2006 Thats very clever. style="vertical-align:middle" emoid=":wub:" border="0" alt="wub.gif" /> flattery always goes a long way with me andi style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> Quote Link to comment Share on other sites More sharing options...
Tigzâ„¢ Posted May 31, 2006 Report Share Posted May 31, 2006 I was meaning the way the Turbo works but your pic is very clever as well lol Quote Link to comment Share on other sites More sharing options...
nfbr Posted May 31, 2006 Report Share Posted May 31, 2006 style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> Quote Link to comment Share on other sites More sharing options...
G40chris Posted June 11, 2006 Report Share Posted June 11, 2006 good description there nfbr Quote Link to comment Share on other sites More sharing options...
Adam-D Posted June 25, 2006 Report Share Posted June 25, 2006 who is the best for tuningand what gains can be expected for the money?looked at a company called cybox? ive also heard good things about jabbasport Quote Link to comment Share on other sites More sharing options...
nfbr Posted June 25, 2006 Report Share Posted June 25, 2006 who is the best for tuningand what gains can be expected for the money?looked at a company called cybox? ive also heard good things about jabbasporti think jabbasport rule the roost for Diesel Remapping...anyone who argues differently would not be able to prove a thing. Quote Link to comment Share on other sites More sharing options...
ArosaPD Posted June 25, 2006 Report Share Posted June 25, 2006 i think jabbasport rule the roost for Diesel Remapping...anyone who argues differently would not be able to prove a thing.I'll second that!! Quote Link to comment Share on other sites More sharing options...
Max69vk Posted June 25, 2006 Report Share Posted June 25, 2006 From a personal point of view I'd have to go with superchips. Quality service & awesome results from their chips. Quote Link to comment Share on other sites More sharing options...
ArosaPD Posted June 25, 2006 Report Share Posted June 25, 2006 From a personal point of view I'd have to go with superchips. Quality service & awesome results from their chips.Dont Superchips just do a generic remap, whereby Jabba do a custom re-map?Mark style="vertical-align:middle" emoid=":confused:" border="0" alt="confused.gif" /> Quote Link to comment Share on other sites More sharing options...
Max69vk Posted June 25, 2006 Report Share Posted June 25, 2006 The initial chip has a generic setup but it is possible to tweak on a RR. Quote Link to comment Share on other sites More sharing options...
nfbr Posted June 25, 2006 Report Share Posted June 25, 2006 Its not a chip max... Believe me its not a chip...As a small test, Remove your ECU and try opening it style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> completely bomb proof. Quote Link to comment Share on other sites More sharing options...
Adam-D Posted June 26, 2006 Report Share Posted June 26, 2006 how much would a re-map cost at jabba?im not after out and out power, i want it as reliable and economical as it was built, or better if thats possiblebig power usually means a compromise to reliability, but a little more wouldnt hurt style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
Max69vk Posted June 26, 2006 Report Share Posted June 26, 2006 Its not a chip max... Believe me its not a chip...As a small test, Remove your ECU and try opening it style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> completely bomb proof.Yeah sorry, meant remap but 'chip' is just the first thing that seems to trip off the tongue style="vertical-align:middle" emoid=":P" border="0" alt="tongue.gif" /> Quote Link to comment Share on other sites More sharing options...
