dlyall Posted November 30, 2005 Report Share Posted November 30, 2005 Does anyone know if the 1.0 is an interference engine or not? Ours is coming up to 38K in 4 years but there's no specific interval for changing the cambelt. The dealer says that they only have to inspect annually after 5 years. I'd rather it didn't let go and cause a large amount of damage but at the same time I don't want to throw money away changing it too early hence the question.If it's not an interference engine I don't have much to worry about if the belt breaks.Has anyone had the belt changed on a 1.0? How much was it and are there any other things worth doing at the same time?TIADave Quote Link to comment Share on other sites More sharing options...
stevewp Posted November 30, 2005 Report Share Posted November 30, 2005 And haven't yet, as ours has done barely over 30k. Also, sadly, I haven't got my laptop with me today or tomorrow so can't check whether it's an interference engine or not (hope someone else can answer that).However, normally the rule of thumb with cambelts is 60k. I recently did mine on my Passat at about 65k (oops) and it looked mint, so I doubt you've anything to worry about yet.However, for how cheap it'll be, it's maybe worth doing. Quote Link to comment Share on other sites More sharing options...
tdwindustries Posted November 30, 2005 Report Share Posted November 30, 2005 All Lupos are variable cam belt - if they need changing, they need changing.The Lupo has known issues with the cam belt tensioner (all models) where it disintegrates.I would say get it done Quote Link to comment Share on other sites More sharing options...
stevewp Posted November 30, 2005 Report Share Posted November 30, 2005 Is it worth changing the tensioner too Tim? Quote Link to comment Share on other sites More sharing options...
tdwindustries Posted November 30, 2005 Report Share Posted November 30, 2005 OOps sorry, yes that would be a good idea style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" />This is all based on a) my car (GTI) style="vertical-align:middle" emoid="B)" border="0" alt="cool.gif" /> my local VW specialist who has seen loads of Lupos for damaged/very dangerous tensioners c) VW service info (from Andi on various threads!) Quote Link to comment Share on other sites More sharing options...
stevewp Posted November 30, 2005 Report Share Posted November 30, 2005 Cheers Tim. Might start to look at this in the spring (can't see there being a problem yet).Hope it's ALOT easier than the cambelt on the Passat - whole of the front of the car has to come off!! Quote Link to comment Share on other sites More sharing options...
noddy Posted November 30, 2005 Report Share Posted November 30, 2005 well if its anything like the 1.4 lupo the left engine mount has to come off so you have to prop up the engine but its not that hard style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> . vw charge about 340 or maybe more cant remember Quote Link to comment Share on other sites More sharing options...
stevewp Posted December 1, 2005 Report Share Posted December 1, 2005 HOW MUCH??? That's extortionate. Quote Link to comment Share on other sites More sharing options...
dlyall Posted December 1, 2005 Author Report Share Posted December 1, 2005 Just spoke to Wayside in MK. They quoted £210+VAT to change the belt and tensioner which isn't too bad. The water pump doesn't need changing unless it's leaking as it has a metal impeller anyway.They couldn't answer whether or not it was an interference engine. Quote Link to comment Share on other sites More sharing options...
stevewp Posted December 1, 2005 Report Share Posted December 1, 2005 That's still sooo expensive. I guess I don't know excatly what's involved, but I really can't see it being more than changing all the belts was on the Passat. Just goes to show how much dealers charge for labour! Quote Link to comment Share on other sites More sharing options...
Scottish_Sport_16V Posted December 1, 2005 Report Share Posted December 1, 2005 My tensioner has went twice one just after i got the car and again this year. Lucky the timin belt didnt slip off.Paddy Quote Link to comment Share on other sites More sharing options...
stevewp Posted December 1, 2005 Report Share Posted December 1, 2005 Seriously?? What sort of mileage had you done each time? Quote Link to comment Share on other sites More sharing options...
LINCOLNSHIRESLUPOGTI Posted December 1, 2005 Report Share Posted December 1, 2005 TDW is exactly right about the tensioner. They are a plastic/composite on the Lupo and are known to break-up and fail. I had mine changed and both cambelts at 45000 miles when I had the headwork done.Think the water pump impellor problem was on the 1.8T was it not? The plastic impellor becomes brittle over time and then cracks and fails causing water pump failure. My mates 1.8T X reg Golf had the water pump impellor failure. Quote Link to comment Share on other sites More sharing options...
Scottish_Sport_16V Posted December 1, 2005 Report Share Posted December 1, 2005 about 45 the first time and 75ish the second steve had the timin belt done both times just for good measure.Paddy Quote Link to comment Share on other sites More sharing options...
Petes 16V Sport Posted December 1, 2005 Report Share Posted December 1, 2005 my cars got 45k on it, should I be thinking of looking at the cambelt? *worried* Quote Link to comment Share on other sites More sharing options...
stevewp Posted December 1, 2005 Report Share Posted December 1, 2005 (edited) Definately think I'll change belt and tensioner in the spring.Is there a better tensioner that can be fitted rather than the plastic/composite rubbish one? Edited December 1, 2005 by stevewp Quote Link to comment Share on other sites More sharing options...
dvfmlfc Posted December 1, 2005 Report Share Posted December 1, 2005 My old MK1 Arosa 1.0MPI had a waterpump leak. Got waterpump and timing belt changed. Car had done 45K, but was advised the timing belt should've last another 20,000 miles.Head gasket still went!!!Andy Quote Link to comment Share on other sites More sharing options...
LINCOLNSHIRESLUPOGTI Posted December 2, 2005 Report Share Posted December 2, 2005 Is there a better tensioner that can be fitted rather than the plastic/composite rubbish one?When VW did both my cambelts at 45000 they also changed the tensioners (and they explained the problem as at the time I was not sure how true the stories about it were). VW supply metal tensioners in place of the plastic/composite ones that are fitted to the cars from new.Cannot remember but seem to think for 2 cambelts and the tensioner kit it was £70ish. I paid no labour as they were doing the head at the same time but asked them how much the cambelt change was out of curiosity and they said about £350 style="vertical-align:middle" emoid=":o" border="0" alt="ohmy.gif" /> Quote Link to comment Share on other sites More sharing options...
stevewp Posted December 2, 2005 Report Share Posted December 2, 2005 Oh well, at least they're replacing it with metal ones now Quote Link to comment Share on other sites More sharing options...
Blackrat Posted December 2, 2005 Report Share Posted December 2, 2005 Oh well, at least they're replacing it with metal ones noware they ? Quote Link to comment Share on other sites More sharing options...
stevewp Posted December 2, 2005 Report Share Posted December 2, 2005 VW supply metal tensioners in place of the plastic/composite ones that are fitted to the cars from new.That was the impression I got Quote Link to comment Share on other sites More sharing options...
