Stiff/heavy clutch after long drive
Hello there,
I noticed that on my Lupo the clutch will become very stiff and "sticky" after driving for long periods (e.g. an hour). When it's cold it's much better (although it's still not as smooth as it could be).
Would this be down to a clutch cable, or is it something more complex like the dreaded pedal box?
- Kyle
Nah, common problem. It's as simple as nothing more than an oil leak. What happens is the primary input shaft seal next to the clutch release bearing leaks very slightly. Almost nothing. But the dust from the clutch sticks to it and forms a glue like substance that binds between the centre of the sliding release bearing and the little metal guide tube.  So the sliding action isn't smooth, becuase the force is at a very slight angle. So it sticks sometimes. Happened to one of my Lupos. It was so stiff I thought I'd either break the pedal box again or snap the cable. I pulled the box out in the end. Nothing wrong with anything except that stickyness after about 100k miles. But changed the clutch and bits, plus rebuilt the gearbox while out... Just in case.
A temporary fix that @Rich and me discussed a while ago but didn't try, is by removing the starter and see if you can "somehow" get to it to clean it with some solvent like petrol or spray some lube or something on the sliding bit.
But. You don't want to contaminate the clutch disc or it'll slip then judder all the time.
  • Like 2
