reececrabb Posted June 13, 2018 Report Share Posted June 13, 2018 Hi was wondering if anyone could help me could just be me being an idiot but on the passenger side the headlight doesn’t work unless on full beam have tried changing the bulbs and no wires that I can see was loose but found it really strange and needs to be sorted ASAP Quote Link to comment Share on other sites More sharing options...
Sausage Posted June 14, 2018 Report Share Posted June 14, 2018 You need a multimeter for volts and continuity to work out what's going on, probably bad connector (green corrosion) bad earth etc. if you cant find it quick enough you could run a bypass. Quote Link to comment Share on other sites More sharing options...
mk2 Posted June 14, 2018 Report Share Posted June 14, 2018 (edited) almost certainly a wiring or connector issue. not switch. not bulb. not indicator switch flash mech. not fuse. not power relay. not earth. i'd start at the light bulb connector and work back. a thin needle or pin pushed thriugh the insulation is your friend (with a multimeter or another tiny light bulb). Edited June 14, 2018 by mk2 Quote Link to comment Share on other sites More sharing options...
