LowerclassLupo Posted January 19, 2015 Report Share Posted January 19, 2015 I have been given an edge amp and speaker box with two speakers in. It has no wires attached and I'm not sure about fitting. Is there a "how to" on here? or can anyone give me a step by step guide with what I'll be needing to fit.Thanks! Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 19, 2015 Report Share Posted January 19, 2015 Could do with seeing what you've got mate. Photo etc Quote Link to comment Share on other sites More sharing options...
LowerclassLupo Posted January 22, 2015 Author Report Share Posted January 22, 2015 Quote Link to comment Share on other sites More sharing options...
LowerclassLupo Posted January 22, 2015 Author Report Share Posted January 22, 2015 If any more pictures are needed let me know. Would love some help! Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 23, 2015 Report Share Posted January 23, 2015 OK, well the easiest way is to take the left and right rear from the headunit straight into the amp (white and red) then you need get some decent speaker wire and run it to the speakers. Poundland do speaker wire for... hmm, a pound, that's not too bad.You obviously need to wire in the remote wire as well so the amp powers on when your radio does. Get a nice fat accessory wire coming from your battery too. Quote Link to comment Share on other sites More sharing options...
LowerclassLupo Posted January 23, 2015 Author Report Share Posted January 23, 2015 Ok.. So I run a wire from my battery that connects to what on the amp? And what's the remote wire look like on the head unit? How would I connect the ends of the speaker cable to the red and white holes in the amp? Because that's bare wire and that red and white is a plug type hole.. Thanks! Sorry completely no idea when it comes to speakers.. Give me mechanical stuff and I'm fine. Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 23, 2015 Report Share Posted January 23, 2015 Haha, not a problem. There's people on here who know more about it than me. I just know the basics.1. Accessory wire, big fat cable, something like a 8 AWG wire. That should handle about 1200 watts. You can go fatter or thinner, but one of the positives of running a fat accessory cable is that you can take feeds off it for other accessories. You're running this to the power terminal on the amp.2. The remote wire is most often blue... if you're using an aftermarket wiring harness.... which I suggest you do. Take a feed off this.3. Red and white 'holes' are for phono cables. You'll have phono cables/sockets on the back of your head unit. Run decent quality phono cables under your carpets to the red and white.4. The Line Out is for your speaker wire to your speakers Good luck, let us know if you need more help. Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 16, 2015 Report Share Posted February 16, 2015 Why would you get alternator wine? Quote Link to comment Share on other sites More sharing options...
Dblock Posted February 16, 2015 Report Share Posted February 16, 2015 Why would you get alternator wine?Some people get interference on the RCA's when running the power the same side as the power. Some don't. Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 16, 2015 Report Share Posted February 16, 2015 Some people get interference on the RCA's when running the power the same side as the power. Some don't. isn't that what a ground loop isolator is for? Quote Link to comment Share on other sites More sharing options...
Dblock Posted February 16, 2015 Report Share Posted February 16, 2015 I think it can be but some of the SQ people insist on running them different sides of the car. Quote Link to comment Share on other sites More sharing options...
DannyParanoid Posted February 17, 2015 Report Share Posted February 17, 2015 I found the ground loop isolator didn't work in the slightest with my whine, neither did running cables on different sides. I had to re-earth the outside of the head unit RCA cables, just did it onto the chassis of the head unit and boom, problem solved! Quote Link to comment Share on other sites More sharing options...
