CLAYTONJONES Posted December 16, 2014 Report Share Posted December 16, 2014 After fitting a new ballast the xenon is pointing right up at the sky now, i have adjusted them before but for some reason when i turn the wheel on top it just spins and does nothing. I have now got the headlight out to look inside and everything looks fine. Anyone have any ideas?Cheers Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted December 16, 2014 Author Report Share Posted December 16, 2014 I sorted this in the end Quote Link to comment Share on other sites More sharing options...
Rich Posted December 17, 2014 Report Share Posted December 17, 2014 How ? Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted December 17, 2014 Author Report Share Posted December 17, 2014 How ?The white dial on top wouldn't adjust the wheel on the back so i got a little flat bladed in one of the groves to try turn it and that seemed to free it Quote Link to comment Share on other sites More sharing options...
Silver! Posted December 18, 2014 Report Share Posted December 18, 2014 Mine were pointing to the ground. Got them reset in VAGCOM yesterday; all is well now. Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted December 18, 2014 Author Report Share Posted December 18, 2014 Mine were pointing to the ground. Got them reset in VAGCOM yesterday; all is well now.You can't adjust them via VAGCOM can you? You use it to set the headlights so they go into adjustment mode, then you adjust accordingly, then store the settings. Quote Link to comment Share on other sites More sharing options...
Silver! Posted December 18, 2014 Report Share Posted December 18, 2014 I don't know, but the self leveling works through VAGCom which is probably what was out with mine. Reset and watch them find their level.Apparently you need to go careful with the manual adjusters as they are easy to break. Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted December 18, 2014 Author Report Share Posted December 18, 2014 I don't know, but the self leveling works through VAGCom which is probably what was out with mine. Reset and watch them find their level.Apparently you need to go careful with the manual adjusters as they are easy to break.Ah yeah thats right. They do break very easy i found out on a spare on i have! Quote Link to comment Share on other sites More sharing options...
