WS6 Posted August 26, 2014 Report Share Posted August 26, 2014 Started the car for the first time in 2 weeks and it started but felt lumpy. Pulled off the drive and headed down the road, got to just under 3000rpm and engine check light came on. Drove round the block and home, seemed really under powered. Came to put the car back on the drive later today, light comes straight on and stays on, lacks power and sounds a bit 'tappy'. Manual says exhaust emission warning. Anyone else had this? Just want an idea of what it might be before I decide to go to main stealer or just my local garage.Thanks in advanceMark Quote Link to comment Share on other sites More sharing options...
stator Posted August 26, 2014 Report Share Posted August 26, 2014 Take it to a local garage. They'll probably decode it for free if you get them to do the repairs.It could mean anything that light, faulty sensors sometimes Quote Link to comment Share on other sites More sharing options...
mattarosa Posted August 26, 2014 Report Share Posted August 26, 2014 Where in the West Midlands are you in relation to stoke/Buxton? I could scan it for you no problem Quote Link to comment Share on other sites More sharing options...
Pete Posted August 26, 2014 Report Share Posted August 26, 2014 Possibly o2 sensor on it's way out, also I'd say the tappy noise was probably already there but you've just noticed it more now that there is an issue with the car, but stranger things have happened, they could be related, but I doubt it. Quote Link to comment Share on other sites More sharing options...
WS6 Posted August 27, 2014 Author Report Share Posted August 27, 2014 A mate bought his box of tricks round, plugged it in and seems its a misfire on cylinder 1. 4 new spark plugs put in and it seems problem solved, if that's all it then it's nice cheap fix. Makes you wonder what some garages check/replace on a service Quote Link to comment Share on other sites More sharing options...
Pete Posted August 27, 2014 Report Share Posted August 27, 2014 Plugs aren't changed on every service. Every second at best. Quote Link to comment Share on other sites More sharing options...
stator Posted September 1, 2014 Report Share Posted September 1, 2014 Sparks should be checked on every service though, although obviously you can't see many faults Quote Link to comment Share on other sites More sharing options...
