yaash16v Posted August 4, 2010 Report Share Posted August 4, 2010 hi got a lupo gti iv lowerd it but i wanner go lower but cant because of the drive shaft is touchin the chassis is there any way of getting around this i knw a lot of people cut abit out of the chassis but i dont wanner do that is there another way if some one cud helpthanks Quote Link to comment Share on other sites More sharing options...
Barnsley-Arosa Posted August 4, 2010 Report Share Posted August 4, 2010 Getting the chassis notched is the only way as far as I know Quote Link to comment Share on other sites More sharing options...
timthetinyhorse Posted August 4, 2010 Report Share Posted August 4, 2010 you are deffo looking at a chasis notch no other way that this to ge round the problem, not a huge job if you know what your doing and your good with a welder and metal work but i wouldnt reccomend it if your not so hot with the welder.hope this is of some helpcheersrob Quote Link to comment Share on other sites More sharing options...
yaash16v Posted August 4, 2010 Author Report Share Posted August 4, 2010 is it safe to do that? Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted August 4, 2010 Report Share Posted August 4, 2010 Safer than than juggling used smack needles.Yeah its pretty safe , its just a small section cut out in an arc then welded together and sealed up with , well sealant Quote Link to comment Share on other sites More sharing options...
Silver! Posted August 5, 2010 Report Share Posted August 5, 2010 You could get your drive shaft bent to avoid it. ...but that would only work for less than 50% of each revolution. Quote Link to comment Share on other sites More sharing options...
bobbo Posted August 5, 2010 Report Share Posted August 5, 2010 ....or notch your drivehsaft. Quote Link to comment Share on other sites More sharing options...
chris c Posted August 6, 2010 Report Share Posted August 6, 2010 You could get your drive shaft bent to avoid it....but that would only work for less than 50% of each revolution.does this work might try it chassis notch is the best way just make sure its welded properly and use quite thick steel to compensate Quote Link to comment Share on other sites More sharing options...
timthetinyhorse Posted August 7, 2010 Report Share Posted August 7, 2010 ha ha ha ha the replys on this thread have made my day Quote Link to comment Share on other sites More sharing options...
karl Posted August 8, 2010 Report Share Posted August 8, 2010 hi got a lupo gti iv lowerd it but i wanner go lower but cant because of the drive shaft is touchin the chassis is there any way of getting around this i knw a lot of people cut abit out of the chassis but i dont wanner do that is there another way if some one cud helpthanksCutting a piece out of the chassis leg will reduce the strength of it and should you have a front end smash you may well regret having done it due to it being part of the crumple zone.Anyway if you do take a welder to it just make sure you clear the wax out (VW put this in there to stop them rusting ) and have a fire extinguisher to hand just in case . Quote Link to comment Share on other sites More sharing options...
