jamhops Posted June 15, 2010 Report Share Posted June 15, 2010 I looked behind the heating controls and the ash tray but cant seem to find anything so wonder if I am missing something or looking in the wrong place or if it even exists?Thanks for any helpBen Quote Link to comment Share on other sites More sharing options...
jonnykell1980 Posted June 16, 2010 Report Share Posted June 16, 2010 not sure where they are on yours but most manufacturers generally put them under the dash above the pedals sort of area, sometimes near your fuse box, behind an easily removable panel on drivers side lower dash, behind a easily removable panel in the center console. ive got a 98 1.4 mpi arosa and mines above the fuse box that is located behind a panel at the right hand side of the steering wheel low down on the dash. yours obviously is a different engine so might be slightly different but id try there. good luck. Quote Link to comment Share on other sites More sharing options...
Tallika_Fan Posted June 16, 2010 Report Share Posted June 16, 2010 I have an 02 plate arosa tdi and it's behind the ash tray. I wouldn't have thought that they'd have moved it between models and years. Quote Link to comment Share on other sites More sharing options...
bluebottle Posted June 16, 2010 Report Share Posted June 16, 2010 I have an 02 plate arosa tdi and it's behind the ash tray. I wouldn't have thought that they'd have moved it between models and years.Yes, it's the same on my car (just to make clear, you have to open the ashtray/lighter cover flap, then lift out the ashtray insert, then you can see it) Quote Link to comment Share on other sites More sharing options...
cardaft Posted July 8, 2010 Report Share Posted July 8, 2010 You confused me there, a 99 Arosa TDi! Only 1.7SDis were made in 99 in the S1 body. So yours should be the same as the other S1 above, above the fuse box. Quote Link to comment Share on other sites More sharing options...
